Jump to navigation
Jump to search
Battery generations overview
๐ 27 kWh Battery (2015โ2017)
- Battery Capacity: 27 kWh usable (30.5 kWh gross) [Generation 1]
- Motor Power: 81.4 kW (109 hp)
- Torque: 285 Nm (210 lb-ft)
- 0โ100 km/h: ~9.5 seconds
- Top Speed: 145 km/h (90.1 mph)
- Charging:
- AC: 6.6 kW on-board charger
- DC Fast Charging: CHAdeMO up to 100 kW
- Range: ~150 km (EPA)
- Battery Type: Lithium-ion polymer
- Voltage: 360 V
- Weight: ~277 kg
- Cooling: Air-cooled
๐ 30 kWh Battery (2017โ2019)
- Battery Capacity: 30 kWh usable (31.8 kWh gross) [Generation 2]
- 0โ100 km/h: ~9.2 seconds
- Charging:
- Range: ~182 km (EPA)
- Voltage: 375 V
- Weight: ~290 kg
๐ 39.2 kWh Battery (2020โ2023)
- Battery Capacity: 39.2 kWh usable [Generation 3]
- Motor Power: 100 kW (136 hp)
- Torque: 395 Nm
- 0โ100 km/h: ~9.9 seconds
- Top Speed: 157 km/h
- Charging:
- AC: 7.2 kW on-board charger
- DC Fast Charging: CCS up to 100 kW
- Range: Up to 276 km (WLTP)
- Voltage: 327 V
- Weight: ~317 kg
- Cooling: Liquid-cooled
๐ 64 kWh Battery (2020โ2024)
- Battery Capacity: 64 kWh usable (67.5 kWh gross) [Generation 4]
- Motor Power: 150 kW (204 hp)
- Torque: 395 Nm
- 0โ100 km/h: ~7.9 seconds
- Top Speed: 167 km/h
- Charging:
- Range: Up to 452 km (WLTP)
- Voltage: 356 V
- Weight: ~457 kg
Battery generation 1
