Honda Accelerator Pedal Sensor
Revision as of 19:25, 18 January 2025 by Maboyce (talk | contribs) (General Information: Added dimensioned photos.)
General Information
A better image would be nice, but this is what the sensor looks like
The original cable is shielded to avoid interference from other sources and resulting unwanted acceleration or deceleration.
Honda accelerator pedal sensor connector pinout[1]
The voltage from both sensors ramps linearly from the fully released position to the fully depressed position[2]. The pedal should be supplied with a reasonable stable and accurate 5V supply to ensure a proper readout.
Voltage Output of Throttle Sensors (P/N 37971-RCA-A01)
Pedal Position Sensor 1 Sensor 2
Fully Released 0.05 V 4.30 V
Fully Depressed 0.10 V 4.90 V
Versions
Selected Versions
Part Number Cars Used In Electrical Connector Remarks
  • 37971-RDJ-A01
  • 37971-RCA-A01
  • 37971-RBB-003
  • For Acura Mdx 2003-2006
  • For Acura Tl 2004-2008
  • For Acura Tsx 2004-2008
  • For Honda Accord 2003-2007
  • For Honda Cr-v 2005-2006
  • For Honda Element 2007-2011
  • For Honda Pilot 2005-2008
  • For Honda Ridgeline 2006-2014
  • sumitomo HX040 6pin
  • Housing F(6189-1012)
  • Retainer 6918-2056
  • 0.3-0.5mm2 F(8100-3067)
  • 0.75-1.25mm2 F(8100-3068)
  • Seal D1.1-1.6 (7165-1075)
  • Seal D1.6-1.9 (7165-0621)
  • Seal D1.8-2.2 (7165-0622)
Connector can be found on Aliexpress
Photos
Side view, P/N 37971-RCA-A01 (Honda Element)
Side view 2, P/N 37971-RCA-A01 (Honda Element)
Rear view, P/N 37971-RCA-A01 (Honda Element)
Underside, P/N 37971-RCA-A01 (Honda Element)
With cover and bracket, P/N 37971-RCA-A01 (Honda Element)
