Zombieverter Parameters and Spot Values
I | Name | Value | Unit | Minimum | Maximum | Default | Notes | Additional notes |
- General Setup | ||||||||
0 | Inverter | 0 | 8 | 0 | ||||
1 | Vehicle | 0 | 8 | 0 | ||||
2 | Transmission | 0 | 1 | 0 | ||||
3 | interface | 0 | 3 | 0 | ||||
4 | chargemodes | 0 | 6 | 0 | ||||
5 | InverterCan | 0 | 1 | 0 | ||||
6 | VehicleCan | 0 | 1 | 1 | ||||
7 | ShuntCan | 0 | 1 | 0 | ||||
8 | LimCan | 0 | 1 | 0 | ||||
9 | ChargerCan | 0 | 1 | 1 | ||||
10 | BMSCan | 0 | 1 | 1 | ||||
11 | OBD2Can | 0 | 1 | 0 | ||||
12 | CanMapCan | 0 | 1 | 0 | ||||
13 | DCDCCan | 0 | 1 | 1 | ||||
14 | GearLvr | 0 | 3 | 0 | ||||
15 | MotActive | 0 | 2 | 0 | ||||
- Throttle | ||||||||
16 | potmin | dig | 0 | 4095 | 0 | |||
17 | potmax | dig | 0 | 4095 | 4095 | |||
18 | pot2min | dig | 0 | 4095 | 4095 | |||
19 | pot2max | dig | 0 | 4095 | 4095 | |||
20 | regenrpm | rpm | 100 | 10000 | 1500 | |||
21 | regenendrpm | rpm | 100 | 10000 | 100 | |||
22 | regenmax | % | -30 | 0 | -10 | |||
23 | regenBrake | % | -30 | 0 | -10 | |||
24 | regenramp | %/10ms | 0.09 | 100 | 100 | |||
25 | potmode | 0 | 1 | 0 | ||||
26 | dirmode | 0 | 4 | 1 | ||||
27 | reversemotor | 0 | 1 | 0 | ||||
28 | throtramp | %/10ms | 0.09 | 100 | 100 | |||
29 | throtramprpm | rpm | 0 | 20000 | 20000 | |||
30 | revlim | rpm | 0 | 20000 | 6000 | |||
31 | bmslimhigh | % | 0 | 100 | 50 | |||
32 | bmslimlow | % | -100 | 0 | -1 | |||
33 | udcmin | V | 0 | 1000 | 450 | |||
34 | udclim | V | 0 | 1000 | 520 | |||
35 | idcmax | A | 0 | 5000 | 5000 | |||
36 | idcmin | A | -5000 | 0 | -5000 | |||
37 | tmphsmax | �C | 50 | 150 | 85 | |||
38 | tmpmmax | �C | 70 | 300 | 300 | |||
39 | throtmax | % | 0 | 100 | 100 | |||
40 | throtmin | % | -100 | 0 | -100 | |||
41 | throtmaxRev | % | 0 | 100 | 30 | |||
42 | throtdead | % | 0 | 50 | 10 | |||
43 | RegenBrakeLight | % | -100 | 0 | -15 | |||
44 | throtrpmfilt | rpm/10ms | 0.09 | 200 | 15 | |||
- Gearbox Control | ||||||||
45 | Gear | 0 | 2 | 0 | ||||
46 | OilPump | % | 0 | 100 | 50 | |||
- Cruise Control | ||||||||
47 | cruisestep | rpm | 1 | 1000 | 200 | |||
48 | cruiseramp | rpm/100ms | 1 | 1000 | 20 | |||
49 | regenlevel | 0 | 3 | 2 | ||||
- Contactor Control | ||||||||
50 | udcsw | V | 0 | 1000 | 330 | |||
51 | cruiselight | 0 | 1 | 0 | ||||
52 | errlights | 0 | 255 | 0 | ||||
- Communication | ||||||||
53 | CAN3Speed | 0 | 2 | 0 | ||||
- Charger Control | ||||||||
54 | BattCap | kWh | 0.09 | 250 | 22 | |||
55 | Voltspnt | V | 0 | 1000 | 395 | |||
56 | Pwrspnt | W | 0 | 12000 | 1500 | |||
57 | IdcTerm | A | 0 | 150 | 0 | |||
58 | CCS_ICmd | A | 0 | 150 | 0 | |||
59 | CCS_ILim | A | 0 | 350 | 100 | |||
60 | CCS_SOCLim | % | 0 | 100 | 80 | |||
61 | SOCFC | % | 0 | 100 | 50 | |||
62 | Chgctrl | 0 | 2 | 0 | ||||
63 | ChgAcVolt | Vac | 0 | 250 | 240 | |||
64 | ChgEff | % | 0 | 100 | 90 | |||
- DC-DC Converter | ||||||||
65 | DCdc_Type | 0 | 1 | 0 | ||||
66 | DCSetPnt | V | 9 | 15 | 14 | |||
- Battery Management | ||||||||
67 | BMS_Mode | 0 | 3 | 0 | ||||
68 | BMS_Timeout | sec | 1 | 120 | 10 | |||
69 | BMS_VminLimit | V | 0 | 10 | 3 | |||
70 | BMS_VmaxLimit | V | 0 | 10 | 4.18 | |||
71 | BMS_TminLimit | �C | -100 | 100 | 5 | |||
72 | BMS_TmaxLimit | �C | -100 | 100 | 50 | |||
- Heater Module | ||||||||
73 | Heater | 0 | 2 | 0 | ||||
74 | Control | 0 | 2 | 0 | ||||
75 | HeatPwr | W | 0 | 6500 | 0 | |||
76 | HeatPercnt | % | 0 | 100 | 0 | |||
- RTC Module | ||||||||
77 | Set_Day | 0 | 6 | 0 | ||||
78 | Set_Hour | Hours | 0 | 23 | 0 | |||
79 | Set_Min | Mins | 0 | 59 | 0 | |||
80 | Set_Sec | Secs | 0 | 59 | 0 | |||
81 | Chg_Hrs | Hours | 0 | 23 | 0 | |||
82 | Chg_Min | Mins | 0 | 59 | 0 | |||
83 | Chg_Dur | Mins | 0 | 600 | 0 | |||
84 | Pre_Hrs | Hours | 0 | 59 | 0 | |||
85 | Pre_Min | Mins | 0 | 59 | 0 | |||
86 | Pre_Dur | Mins | 0 | 60 | 0 | |||
- General Purpose I/O | ||||||||
87 | Out1Func | 0 | 13 | 6 | ||||
88 | Out2Func | 0 | 13 | 7 | ||||
89 | Out3Func | 0 | 13 | 3 | ||||
90 | SL1Func | 0 | 13 | 0 | ||||
91 | SL2Func | 0 | 13 | 0 | ||||
92 | PWM1Func | 0 | 14 | 0 | ||||
93 | PWM2Func | 0 | 14 | 4 | ||||
94 | PWM3Func | 0 | 15 | 2 | ||||
95 | GP12VInFunc | 0 | 13 | 12 | ||||
96 | HVReqFunc | 0 | 13 | 11 | ||||
97 | GPA1Func | 0 | 2 | 0 | ||||
98 | GPA2Func | 0 | 2 | 0 | ||||
99 | ppthresh | dig | 0 | 4095 | 2500 | |||
100 | BrkVacThresh | dig | 0 | 4095 | 2500 | |||
101 | BrkVacHyst | dig | 0 | 4095 | 2500 | |||
- ISA Shunt Control | ||||||||
102 | IsaInit | 0 | 1 | 0 | ||||
103 | Type | 0 | 2 | 0 | ||||
- PWM Control | ||||||||
104 | Tim3_Presc | 1 | 72000 | 719 | ||||
105 | Tim3_Period | 1 | 100000 | 7200 | ||||
106 | Tim3_1_OC | 1 | 100000 | 3600 | ||||
107 | Tim3_2_OC | 1 | 100000 | 3600 | ||||
108 | Tim3_3_OC | 1 | 100000 | 3600 |
Spot Values
Name | Value | Unit | CAN Id | Position | Bits | Gain | Map to CAN | Notes | Additional Notes |
version | 2.17.A | TX�RX | |||||||
opmode | Off | TX�RX | |||||||
chgtyp | Off | TX�RX | |||||||
lasterr | NONE | TX�RX | |||||||
status | PotPressed | TX�RX | |||||||
udc | 0 | V | TX�RX | ||||||
udc2 | 0 | V | TX�RX | ||||||
udc3 | 0 | V | TX�RX | ||||||
deltaV | 0 | V | TX�RX | ||||||
INVudc | 0 | V | TX�RX | ||||||
power | 0 | kW | TX�RX | ||||||
idc | 0 | A | TX�RX | ||||||
KWh | 0 | kwh | TX�RX | ||||||
AMPh | 0 | Ah | TX�RX | ||||||
SOC | 100 | % | TX�RX | ||||||
BMS_Vmin | 0 | V | TX�RX | ||||||
BMS_Vmax | 0 | V | TX�RX | ||||||
BMS_Tmin | 0 | �C | TX�RX | ||||||
BMS_Tmax | 0 | �C | TX�RX | ||||||
BMS_ChargeLim | 9999 | A | TX�RX | ||||||
speed | 0 | rpm | TX�RX | ||||||
Veh_Speed | 0 | kph | TX�RX | ||||||
torque | 0 | dig | TX�RX | ||||||
pot | 12 | dig | TX�RX | ||||||
pot2 | 5 | dig | TX�RX | ||||||
potbrake | 0 | dig | TX�RX | ||||||
brakepressure | 0 | dig | TX�RX | ||||||
potnom | 0 | % | TX�RX | ||||||
dir | Neutral | TX�RX | |||||||
tmphs | 0 | �C | TX�RX | ||||||
tmpm | 0 | �C | TX�RX | ||||||
tmpaux | 0 | �C | TX�RX | ||||||
uaux | 14.68 | V | TX�RX | ||||||
canio | TX�RX | ||||||||
FrontRearBal | 50 | % | TX�RX | ||||||
cruisespeed | 0 | rpm | TX�RX | ||||||
cruisestt | None | TX�RX | |||||||
din_cruise | Off | TX�RX | |||||||
din_start | Off | TX�RX | |||||||
din_brake | Off | TX�RX | |||||||
din_forward | Off | TX�RX | |||||||
din_reverse | Off | TX�RX | |||||||
din_bms | Off | TX�RX | |||||||
din_12Vgp | Off | TX�RX | |||||||
handbrk | Off | TX�RX | |||||||
Gear1 | Off | TX�RX | |||||||
Gear2 | Off | TX�RX | |||||||
Gear3 | Off | TX�RX | |||||||
T15Stat | Off | TX�RX | |||||||
InvStat | Off | TX�RX | |||||||
GearFB | LOW | TX�RX | |||||||
CableLim | 0 | A | TX�RX | ||||||
PilotLim | 0 | A | TX�RX | ||||||
PlugDet | Off | TX�RX | |||||||
PilotTyp | Absent | TX�RX | |||||||
CCS_I_Avail | 0 | A | TX�RX | ||||||
CCS_V_Avail | 0 | V | TX�RX | ||||||
CCS_I | 0 | A | TX�RX | ||||||
CCS_Ireq | 0 | A | TX�RX | ||||||
CCS_V | 0 | V | TX�RX | ||||||
CCS_V_Min | 0 | V | TX�RX | ||||||
CCS_V_Con | 0 | V | TX�RX | ||||||
hvChg | Off | TX�RX | |||||||
CCS_COND | NotRdy | TX�RX | |||||||
CCS_State | 0 | s | TX�RX | ||||||
CP_DOOR | CLOSED | TX�RX | |||||||
CCS_Contactor | Off | TX�RX | |||||||
Day | Sun | TX�RX | |||||||
Hour | 0 | H | TX�RX | ||||||
Min | 3 | M | TX�RX | ||||||
Sec | 25 | S | TX�RX | ||||||
ChgT | 0 | M | TX�RX | ||||||
HeatReq | Off | TX�RX | |||||||
U12V | 0 | V | TX�RX | ||||||
I12V | 0 | A | TX�RX | ||||||
ChgTemp | 0 | �C | TX�RX | ||||||
AC_Volts | 0 | V | TX�RX | ||||||
AC_Amps | 0 | A | TX�RX | ||||||
canctr | 0 | dig | TX�RX | ||||||
cpuload | 0.78 | % | TX�RX | ||||||
PPVal | 0 | dig | TX�RX | ||||||
BrkVacVal | 0 | dig | TX�RX | ||||||
tmpheater | 0 | �C | TX�RX | ||||||
udcheater | 0 | V | TX�RX | ||||||
powerheater | 0 | W | TX�RX | ||||||
serial | 43212553 | TX�RX |
