Renault Kangoo 36
The phase 2 Renault Kangoo 36kWh pack consists of 12 modules, roughly 16kg 14x21x31 cm each. The usable capacity is apparently 33kWh.
There are 2 external Low voltage Connectors
Grey Yazaki x
| Pin | Internal Wire | Function |
| 1 | Black | 12v BMS supply via 10a fuse |
| 2 | x | |
| 3 | x | |
| 4 | x | |
| 5 | x | |
| 6 | Yellow | Can High |
| 7 | White | 12v Contactor supply via 15a fuse |
| 8 | x | |
| 9 | x | |
| 10 | x | |
| 11 | x | |
| 12 | Blue | Can Low |
Black Yazaki 7283-8854-30
| 1 | Black | Ground |
| 2 | x | |
| 3 | Green | Main Contactor (ground to close) |
| 4 | x | |
| 5 | Blue | Pre-charge relay (ground to close) |
