The Status cell will have several status like:
- Suggested,
- Approved, looks good go ahead and put in firmware
- STD, is established and standard in firmware
Sign with your forum name, please do not delete any rows, just add a new.
Openiverter CAN data out.
Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Status
Sign
DIR
0x123
123
123
123
123
123
123
123
123
test
joromy
FWD
0x123
123
test
joromy
REW
0x123
123
joromy
P/N
0x123
123
joromy
Simp BMS CAN data out.
Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Satus
Sign
SOC
0x355
0-100
STD
joromy
BMS Boot
0x355
0
Status
Suggested
joromy
BMS Ready
0x355
1
Status
Suggested
joromy
BMS Drive
0x355
2
Status
Suggested
joromy
BMS Charge
0x355
3
Status
Suggested
joromy
BMS Precharge
0x355
4
Status
Suggested
joromy
BMS Error
0x355
5
Status
Suggested
joromy
BMS Heat/cool
0x355
6
Staus
Suggested
joromy
Pack Volt
0x356
LSB
MSB
STD
joromy
Tot. Amps
0x356
LSB
MSB
STD
joromy
Avg. celltemp
0x356
LSB
MSB
STD
joromy
Lo cellvolt
0x373
LSB
MSB
Suggested
joromy
Hi cellvolt
0x373
LSB
MSB
Suggested
joromy
Lo celltemp
0x373
LSB
MSB
Suggested
joromy
HI celltemp
0x373
LSB
MSB
Suggested
joromy
Tesla charger CAN data out (only DUE based board)
Function
CAN-Id
Byte0
Byte1
Byte2
Byte3
Byte4
Byte5
Byte6
Byte7
Description
Status
Sign
Unconnected
0x3D8
0
Suggested
joromy
Buttonpress
0x3D8
1
Suggested
joromy
Connected
0x3D8
2
Suggested
joromy
EVSE disable
0x3D8
0
Normal mode
Suggested
joromy
EVSE enable
0x3D8
1
AC enable, no charge
Suggested
joromy
