Using FOC Software
Revision as of 08:34, 6 February 2020 by Johu (talk | contribs) (Created page with "Permanent magnet motors have turned out only to be well drivable when their stator current is controlled by means of a feedback current loop. Due to this, the existing feed fo...")
Permanent magnet motors have turned out only to be well drivable when their stator current is controlled by means of a feedback current loop. Due to this, the existing feed forward controlled used for induction motors could not be extended for use with permanent magnet motors. Therefor the well known field oriented control approach was implemented in a separate software.
