Modifications to original wiring
Jump to navigation
Jump to search
MODIFICATIONS: (Please read the Ford Ranger treads, for details)
- Replace temp sensor in inverter
- Reuse old connector in inverter ECU
- One new wire, from backup light to inverter.
- Cut old J1850 bus, and connect to CAN bus
- Cut some wires going to accelerator pot, connect to BMS, cruise switch, oil sensor and diplay.
- Cut one wire going to the gear shift switch, use for 5V to the oil pressure sensor.
- Remove two fault lamps, or reconnect to BMS.
