Modifications to original wiring
MODIFICATIONS: (Please read the other Ford Ranger treads, for details) Replace temp sensor in inverter Reuse old connector in inverter ECU One new wire, from backup light to inverter. Cut old J1850 bus, and connect to CAN bus Cut some wires going to accelerator pot, connect to BMS, cruise switch, oil sensor and diplay. Cut one wire going to the gear shift switch, use for 5V to the oil pressure sensor. Remove two fault lamps, or reconnect to BMS.
