Audi A2 Conversion
Revision as of 07:17, 7 February 2022 by Geduxaz (talk | contribs) (ECU)
On this page we describe the conversion of an Audi A2 1.4i petrol to electric propulsion. We will use the following components:
  • Nissan Leaf 24 kWh battery pack with original BMS
  • Toyota Prius Gen 2 (2004-2009) transaxle with matching inverter
  • openinverter Prius Gen2 motor controller
  • openinverter main board running stm32-car (VCU in ECU enclosure)
Pin mapping
We start out by mapping out useful pins of the original wire harness
ECU
The ECU has two connector slots, a smaller one with pins 82-121 and a larger one with pins 1-81. Here we map out pins useful to us
ECU pinout 1.4i (AUA, BBY)
# orig function our function wire color
1,2 GND
3 permanent 12V ro
4 ignition 12V ro/sw
5 Lambda (first) heater gr
28 From generator (maybe DF) li/bl
33 Throttle second pot +5V gr/ge
34 Throttle second pot (signal) br/gn
35 Throttle first pot (signal) ge/bl
36 Throttle first pot +5V br/ro
38 To cruise control switch * ws
39 Clutch pedal sensor * if installed ro/ge
40 To Climate control display sw/ge
41 To Climate control display sw/gr
43 To instrument cluster (function unknown) gn/sw
51 Lambda (first) signal bl/ws
52 Lambda (first) signal ge
54 To instrument cluster (function unknown) bl/ws
55 Brake light switch NC to +12V ws/ro
56 Brake light switch NO to +12V ro/sw
57 To cruise control switch * bl/ro
58 CAN L or/br
60 CAN H or/sw
63 Lambda (second) heater li/ro
64 Charcoal filter solenoid bl/ge
65 Fuel pump relay- control ro/br
68 Lambda (second) signal bl/br
69 Lambda (second) signal ro/li
70 Lambda (first) signal bl
71 Lambda (first) signal sw
72 Throttle second pot GND gr
73 Throttle first pot GND ge/li
75 To cruise control switch * bl/sw
76 To cruise control switch * sw/ro
82 Engine speed sensor gr/br
83 Throttle body sens power ro/gn
84 Throttle body sens 2 gn/bl
85 Intake manifold Temp/Pressure gr
86 Hall sender G40 signal ro/sw
87 Engine speed sensor gn/sw
88 Injector 3 sw/li
89 Injector 4 li/sw
91 Throttle body sens power ro/bl
92 Throttle body sens 1 li/ro
93 Coolant temp sensor gr/ws
96 Injector 1 br/bl
97 injector 2 sw/gn
98 +5V wiring to engine bay gn/li
99 Knock sensor ws
100 EGR pot br/li
102 Ignition coil bank 1 gn/ws
103 Ignition coil bank 2 gn/ro
106 Knock sensor br
108 GND for engine sensors gr/ro
109 Intake manifold Temp/Pressure bl/gn
114 EGR mot li/ge
117 Throttle body mot gn
118 Throttle body mot br/sw
