Toyota P112 CVT
Description
The P112 is considered a second generation e-CVT.
Applications
- Toyota Prius (2004-2009)
Specifications
MG1
Rated Voltage: 500V
Max Output: ?
MAX RPM: 10000
Power split device planetary gearset ratio is ???.
MG2
Rated Voltage: 500V
Max Output Power: 68 HP (50 KW)
Max Output Torque: 400 NM (295 lb ft)
Max RPM:
Final Drive Ratio
MG2 to final drive ratio: 4.113:1
Ring to pinion gear ratio: 2.885:1
Oil Pump
Fluid Capacity
3.8L of Toyota WS fluid.
Weight
236 lbs??
MG1 Stator
MG2 Stator
MG1 Resolver
MG2 Resolver
Park Shift Linkage Motor
Reference
Weber State University: 2004-2009 Prius Transaxle - P112 Deep Dive
