Toyota P112 CVT
Description[edit | edit source]
The P112 is considered a second generation e-CVT.
Applications[edit | edit source]
- Toyota Prius (2004-2009)
Specifications[edit | edit source]
MG1[edit | edit source]
Rated Voltage: 500V
Max Output: ?
MAX RPM: 10000
Power split device planetary gearset ratio is ???.
MG2[edit | edit source]
Rated Voltage: 500V
Max Output Power: 68 HP (50 KW)
Max Output Torque: 400 NM (295 lb ft)
Max RPM:
Final Drive Ratio[edit | edit source]
MG2 to final drive ratio: 4.113:1
Ring to pinion gear ratio: 2.885:1
Oil Pump[edit | edit source]
Fluid Capacity[edit | edit source]
3.8L of Toyota WS fluid.
Dimensions[edit | edit source]
Weight[edit | edit source]
236 lbs??
Connections[edit | edit source]
MG1 Stator[edit | edit source]
MG2 Stator[edit | edit source]
MG1 Resolver[edit | edit source]
MG2 Resolver[edit | edit source]
Park Shift Linkage Motor[edit | edit source]
Reference
Weber State University: 2004-2009 Prius Transaxle - P112 Deep Dive
Wikipedia: Toyota Prius (XW20)
l
