Toyota P111 CVT
Description[edit | edit source]
The P112 is considered a second generation e-CVT.
Applications[edit | edit source]
- Toyota Prius (1998-2003)
Specifications[edit | edit source]
MG1[edit | edit source]
Rated Voltage: 273.6V
Max Output: ?
MAX RPM: 6500
Power split device planetary gearset ratio is ???.
MG2[edit | edit source]
Max Output Power: 44 HP (33 KW)
Max Output Torque: 350 NM (258 lb ft)
Max RPM:
Final Drive Ratio[edit | edit source]
MG2 to final drive ratio 3.901:1
Ring to pinion gear ratio 2.885:1
Oil Pump[edit | edit source]
Fluid Capacity[edit | edit source]
4.6L of Toyota Type T-IV fluid.
Dimensions[edit | edit source]
Weight[edit | edit source]
??? lbs
