VW Hybrid Battery Packs
Revision as of 23:15, 10 February 2021 by Rstevens81 (talk | contribs) (Passat GTE: added pictures & dexcriptions)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Passat GTE
The Battery Module weighs
Module Weight
BMS Board
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
INSERT
Resistor Pic
Fuse
Error creating thumbnail: File with dimensions greater than 12.5 MP
Shunt
Control Board
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
Using Multiple Packs
