VW Hybrid Battery Packs
Revision as of 14:24, 10 February 2021 by Bigpie (talk | contribs) (Golf GTE)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Cooling
Contactors/Pre Charge
Passat GTE
Golf GTE
The control box contains a PEC 250A 250VDC fuse, 2 contactors, a pre-charge relay and resistor, and a current shunt.
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Using Multiple Packs
