VW Hybrid Battery Packs
Specification Overview
Passat GTE
The 9.9 KWH Passat GTE battery pack contains 96S 28AH Samsung cells arranged in to 4 modules of 24S with a liquid cooled headsink down the middle.
Golf GTE
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
BMS
