Getting started with an IVT-S and Arduino Uno CAN bus shield
First of all, set up your Arduino Uno and CAN bus shield.
Once the data is coming in over CAN, we can write a simple program to read the current value from the IVT-S.
There could be a lot of messaged coming back on the CAN bus, so we have to specify a "mask" and "filter" for the CAN message IDs we are interested in. CAN bus message IDs are 11 bytes long, so we will specify a mask of 0x7ff (which is 11111111111 in binary). The message ID of the "Current" reading from an IVT-S is 0x52, so we will specify that as the filter. Using an MCP2515-based shield, we can set up to six different filter IDs.
Once those parameters are set, the data should come streaming in over CAN bus.
The tricky part is that the current measurement comes from the the IVT-S as a buffer of four byte values in big endian order. We have to re-assemble these bytes to get the numerical current value (in mA). Once that's done, we get nice, readable numerical values on the serial console.
Here's the code:
// IVT-S meter using CAN-BUS Shield // electric_dart 2020 #include <SPI.h> #include "mcp_can.h" /*SAMD core*/ #ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE #define SERIAL SerialUSB #else #define SERIAL Serial #endif // the cs pin of the version after v1.1 is default to D9 // v0.9b and v1.0 is default D10 const int SPI_CS_PIN = 10; const int CAN_INT_PIN = 2; MCP_CAN CAN(SPI_CS_PIN); // Set CS pin unsigned char flagRecv = 0; unsigned char len = 0; unsigned char buf[8]; char str[20]; void setup() { SERIAL.begin(115200); while (!SERIAL) { ; // wait for serial port to connect. Needed for native USB port only } while (CAN_OK != CAN.begin(CAN_1000KBPS)) { // init can bus SERIAL.println("CAN BUS Shield init fail"); SERIAL.println("Init CAN BUS Shield again"); delay(100); } SERIAL.println("CAN BUS Shield init ok!"); attachInterrupt(digitalPinToInterrupt(CAN_INT_PIN), MCP2515_ISR, FALLING); // start interrupt /* set receive mask */ CAN.init_Mask(0, 0, 0x7ff); // there are 2 masks in mcp2515, you need to set both of them CAN.init_Mask(1, 0, 0x7ff); // 0x7ff is '11111111111' in binary, so we are checking 11 of the CAN message ID bits /* set receive filter */ CAN.init_Filt(0, 0, 0x521); // there are 6 filters in mcp2515 CAN.init_Filt(1, 0, 0x521); // 0x521 is the CAN mssage ID for IVT-S Current value CAN.init_Filt(2, 0, 0x521); CAN.init_Filt(3, 0, 0x521); CAN.init_Filt(4, 0, 0x521); CAN.init_Filt(5, 0, 0x521); } void MCP2515_ISR() { flagRecv = 1; } void loop() { if (flagRecv) { // check if get data flagRecv = 0; // clear flag // iterate over all pending messages // If either the bus is saturated or the MCU is busy, // both RX buffers may be in use and reading a single // message does not clear the IRQ conditon. while (CAN_MSGAVAIL == CAN.checkReceive()) { // read data, len: data length, buf: data buf CAN.readMsgBuf(&len, buf); unsigned long canId = CAN.getCanId(); if (canId == 0x521) { SERIAL.print("Data received from IVT_Msg_Result_I"); SERIAL.print("\t"); // Convert individual big endian byte values to actual reading long reading = (buf[2] << 24) | (buf[3] << 16) | (buf[4] << 8) | (buf[5]); SERIAL.print(reading); } SERIAL.println(); } } }
