MG PTC Cabin Air Heater
Revision as of 18:27, 27 February 2026 by Larsrengersen (talk | contribs) (Control info added)
MG ZS PTC Air Heater
PTC Air heater assembly found in MG EVs (ZS, MG4, MG5).
Heater is controlled by LIN.
Dimensions are WxLxD 160 x 220 x 33mm for the active part with the control box adding another 30mm in length.
Part Numbers
MG Part Number Vehicles Used it Tested?
10606761 ZS No
LIN Control
  • no timers, counters or CRC are needed, but there is a delay of about 3 seconds until settings are applied
  • Bytes 2E and 2F contain the control messages, 3A has the responses
  • Control is in byte 0+1 of 0x2E Scaling = x25 Little endian So if you want 20% power you need to send decimal 500 which is hex 01F4 So then Byte 0 = 0xF4 and Byte 1 = 0x01 Byte 4 looks to be on/off with 0x96 = ON and 0x00 = Off but it does not fully turn off. I kept seeing a current draw on the bench power supply of 0,07A at 300V. When requesting power 0% this does drop to 0A.
  • Feedback Message 0x3A Byte 5 and 6 contain the actual consumption in W as little endian. So if Byte 5 = CF and Byte 6 = 04 that is 04CF in hex which is 1,2 kW.
  • Below about 250V it stops working. Then 0x3A sends 00 00 00 08 00 00 00 20
  • Above 150 degrees it stops working. Then 0x3A sends 00 00 00 00 01 00 00 20
Connectors
MG PTC Connector Pinout
Low Voltage/Control
KET part number MG644145-5
Hyundai part number 1879002605as
Pin Cross Section Colour Function
2 0.35 Green/White + fused with 5A
3 0.35 Pink/Black LIN
4 0.35 Black GND
High Voltage
1 3.00 Orange HV+ fused with 40A
2 3.00 Orange HV-
MG PTC Connector
MG PTC Connector
