VW Hybrid Battery Packs
Specification Overview
Passat GTE
Golf GTE
Pin | Colour | Notes | |
1 | Orange & Black | CAN H - Power Train | |
2 | Orange & Brown | CAN L - Power Train | |
3 | Blue | Airbag Control Module | |
4 | Purple & Yellow | Pilot line (In) | |
5 | Purple & Yellow | Coolant Value | |
6 | Red & Grey | 12v 30 amp | |
7 | Green | Coolant Pump | |
8 | Black & Green | 12v (IGN) | Fuse 49 on fuse holder C |
9 | Brown | Earth | |
10 | Red & Grey | 12v 30amp Fuse | |
11 | Black & Green | Pilot Line (out) | connects to the HV connector interconnect, then BMS master, then Pilot In, there should be 150ohm resistor instead of the other components |
12 | Black | Airbag Control Module | |
13 | Orange & Grey | CAN H - Hybrid | |
14 | Orange & Brown | CAN L - Hybrid |
E-Golf
Pin | Colour | Connected to external to pack | Connected to internal to pack |
T20q/1 | sw/bl | PIOLT LINE must form a circuit with T20q/14 (J840 T32j/5) | HV connector contacts – J840 T32j/21 |
T20q/2 | gn | Maintenance plug for high voltage system, 12v+ when connected | Junction – J840 T32j/32 + J497 T18c/1,T18c/2 |
T20q/3 | ge | 15a Ignition Live Power | Junction – J840 T32j/14 + J497 T18c/6 |
T20q/4 | ge/rt | Drivetrain CAN-bus High (diagnostic connection) | J840 T32j/3 |
T20q/5 | ge/br | Drivetrain CAN-bus Low (diagnostic connection) | J840 T32j/4 |
T20q/6 | bl/rt | Airbag control unit – SIG+ | J840 T32j/13 |
T20q/7 | bl/ge | Airbag control unit – SIG- | J840 T32j/29 |
T20q/8 | |||
T20q/9 | br | Earth | Junction - J840 T32j/16,/30 + J497 T18c/8,/9,/18 + J1068 T10/1 |
T20q/10 | or/sw | Hybrid CAN-bus High | J840 T32j/18 |
T20q/11 | or/br | Hybrid CAN-bus Low | J840 T32j/19 |
T20q/12 | rt | 30a Permanent Live | Junction - J840 T32j/17 + J497 T18c/10 |
T20q/13 | |||
T20q/14 | sw/gn | PIOLT LINE must form a circuit with T20q/1 (J840 T32j/21) | J840 T32j/5 |
T20q/15 | |||
T20q/16 | |||
T20q/17 | |||
T20q/18 | |||
T20q/19 | |||
T20q/20 |
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
Golf GTE
E-Golf
BMS
Terminals are:
ID | Data |
0x0BA | 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 |
0x0BA | 0x45 0x01 0x28 0x00 0x00 0x00 0x00 0x30 |
Battery Modules
Passat GTE
Golf GTE
E-Golf
Part 1
Part 2
Cooling
Contactors/Pre-Charge
Passat GTE
The Control box contains
- PEC 300A 450VDC fuse
- 1 x Contactor Control Board
Control board Interface Connector | |
The pinout is as follows:
Pin | Function | Wire Colour | Notes |
1 | +12v | Green | Live when service plug installed |
2 | +12v | Green | Live when service plug installed |
3 | |||
4 | COMs | Black/Grey | COM line to J840 (maybe LIN?) |
5 | |||
6 | GND | Brown | GND to battery casing |
7 | |||
8 | GND | Brown/Red | Vehicle GND |
9 | GND | Brown/Red | Vehicle GND |
10 | +12V | Red | KL30 (permenant live) |
11 | |||
12 | |||
13 | |||
14 | CANH | Orange/Blue | 120 OHM, internal to pack only |
15 | CANL | Orange/Brown | 120 OHM, internal to pack only |
16 | +12V | Yellow | KL15 (ignition live) |
17 | |||
18 | GND | Brown/Red | Vehicle GND |
Can output ...
CAN ID | Function | Notes |
000000BB | Shunt, Bytes 1 & 2 (16bit signed integer) | Multiply by 0.00625 to get amps |
18FED007 | ||
0000015B | ||
18FED008 | ||
18FED009 | Bytes 0 & 1 (16bit integer) | Possible Candidate Voltage @ Fuse |
18FED00A | ||
18FED003 | ||
18FED004 | ||
1A55545F | ||
16A95419 | ||
18FED006 | ||
18FED002 | ||
18FED005 |
BMS Control Module
000000BA | Module Wake up | |
1BFFDA1A | ||
1BFFDA19 | ||
1A55540A | ||
1A55540B | ||
1A55540C | ||
1A55540D | ||
1A555410 | ||
1A555411 | ||
1A555412 | ||
1A555413 | ||
1A555414 | ||
1A555415 | ||
1A555416 | ||
1A555417 | ||
1A555418 | ||
1A555419 | ||
1A55541E | ||
1A55541F |
High Voltage Connector
Golf GTE
The control box contains a
- PEC 250A 450VDC fuse
- 2 x Panasonic AEV14012 M28 contactors https://docs.rs-online.com/6251/0900766b80e1fbed.pdf, yazaki 7283-1020 is the connector (would recommend a better contactor, I've welded one of these closed pretty easily)
- Current shunt.
I've now found the can bus messages to control the precharge and main contactors, the example code is here: https://github.com/jamiejones85/VW-GTE-ContactorBox
Pin | Function | Wire Colour | Additional |
1 | Connects to battery case | Black | Ring terminal on the end, maybe for isolation test? Seems to output 5v. |
2 | Gnd | Black | |
3 | N/C | ||
4 | CAN H | White | 125ohm resistance between them. IC501 - TJA1042 |
5 | CAN L | Black | |
6-9 | N/C | ||
10 | 12v | Red | 12V input. |
11 | 12v | Red | 12V input. When supplied, IC204 begins outputting 5V |
12 | 12v ignition | White | Looks to be ignition 12v |
13 | N/C | ||
14 | 12v | White | Enables the 12v to the contactors. |
15-19 | N/C | ||
20 | Pre charge relay switched gnd | Black | Q409 is responsible for switching this to ground. |
21 | Contactor switched gnd | Black | Q408 is responsible for switching this to ground. |
22 | Contactor switched gnd | Black | Q408 is responsible for switching this to ground. |
23 | 12v for precharge relay | Yellow | Isolated from 12v supply, IC401 |
24 | 12v for contactor | Blue | Isolated from 12v supply, IC401 |
25 | 12v for contactor | Red | Isolated from 12v supply, IC401 |
26 | N/C |
2 x V216HC4 unknown
E-Golf
1x PEC 400A fuse
1x Pre-Charge Resistor
1x Voltage based Shunt
1x Capacitor
1x BMS Master Module, J840
Pin out for J497 | ||||
Low voltage external connector | T18c/1 | gn | Service Plug | KL30a when service plug inserted |
T18c/2 | gn | Service Plug | KL30a when service plug inserted | |
T18c/3 | ||||
T18c/4 | sw | J840 Link | direct line to J840 | |
T18c/5 | ||||
T18c/6 | br | GND | Ground of battery casing | |
T18c/7 | ||||
T18c/8 | br | GND | Vehicle Earth | |
T18c/9 | br | GND | Vehicle Earth | |
T18c/10 | rt | KL30a | ||
T18c/11 | ||||
T18c/12 | ||||
T18c/13 | or/br | Hybrid CAN-l | CAN bus for cell modules | |
T18c/14 | or/bl | Hybrid CAN-h | CAN bus for cell modules | |
T18c/15 | ||||
T18c/16 | ge | KL15a | Ignition live | |
T18c/17 | ||||
T18c/18 | br | GND | Vehicle Earth | |
High voltage tap/sense lines | T12i/1a | ws/ge | HV- tap | HV- tap output side drive contactor |
T12i/2a | vi | HV- tap | HV- tap battery negative | |
T12i/3a | ws | HV+ tap | HV+ tap input side precharge relay | |
T12i/4a | rt/bl | HV+ tap | HV+ tap battery positive post fuse | |
T12i/5a | gr | SIG | HV+ shunt high | |
T12i/6a | ||||
T12i/1b | gn | HV+ tap | HV+ tap output side drive contactor | |
T12i/2b | ws/sw | HV- tap | HV- tap external side aux contactor | |
T12i/3b | rt/sw | HV+ tap | HV+ tap battery positive | |
T12i/4b | ws/bl | HV+ tap | HV+ tap external side aux contactor | |
T12i/5b | gr/sw | SIG | HV+ shunt low | |
T12i/6b | ||||
Low voltage contactor drive | T12j/1 | br | GND | Coil – for Precharge Relay |
T12j/2 | br | GND | Coil – for HV+ Drive contactor | |
T12j/3 | br | GND | Coil – for HV- Drive contactor | |
T12j/4 | br | GND | Coil – for HV+ Aux contactor | |
T12j/5 | br | GND | Coil – for HV- Aux contactor | |
T12j/6 | ||||
T12j/7 | sw | CTRL | Coil + for Precharge Relay | |
T12j/8 | ge | CTRL | Coil + for HV+ Drive contactor | |
T12j/9 | rt/ge | CTRL | Coil + for HV- Drive contactor | |
T12j/10 | gn | CTRL | Coil + for HV+ Aux contactor | |
T12j/11 | ||||
T12j/12 | gr | CTRL | Coil + for HV- Aux contactor | |
Battery Tap | T4bx/1 | |||
T4bx/2 | ||||
T4bx/3 | bl | Centre Tap | Centre cell tap from HV battery | |
T4bx/4 |
J840 pin out | |||
T32j/1 | or/bl | Hybrid CAN-h | To cell modules and J497 |
T32j/2 | or/br | Hybrid CAN-l | To cell modules and J497 |
T32j/3 | ge/rt | Power CAN-h | To powertrain CAN bus |
T32j/4 | ge/br | Power CAN-l | To powertrain CAN bus |
T32j/5 | sw/gn | PIOLT | HV connection PIOLT line (must form circuit with T32j/21) |
T32j/6 | |||
T32j/7 | |||
T32j/8 | |||
T32j/9 | |||
T32j/10 | gr | Module KL30a | 12v+ power to cell modules |
T32j/11 | |||
T32j/12 | gn/rt | Enable | Cell module enable power to first module |
T32j/13 | vi | SIG+ | Battery isolation igniter |
T32j/14 | ge | KL15a | Ignition Live power |
T32j/15 | br | GND | 31 Earth connection |
T32j/16 | br | GND | 31 Earth connection (battery case) |
T32j/17 | rt | KL30a | Permenant live |
T32j/18 | or/sw | Hybrid CAN-h | To hybrid CAN bus |
T32j/19 | or/br | Hybrid CAN-l | To hybrid CAN bus |
T32j/20 | sw | J497 link | Direct line to J497 |
T32j/21 | sw/bl | PIOLT | HV connection PIOLT line (must form circuit with T32j/5) |
T32j/22 | |||
T32j/23 | |||
T32j/24 | |||
T32j/25 | |||
T32j/26 | |||
T32j/27 | |||
T32j/28 | gn/bl | Enable Check | Enable signal return from last cell module |
T32j/29 | vi/sw | SIG- | Battery isolation igniter |
T32j/30 | br | GND | 31 Earth connection (battery case) |
T32j/31 | |||
T32j/32 | gn | Service Plug | KL30a power through HV service disconnect |
Using Multiple Packs
I've been using 2 Golf GTE packs in parallel for a while now. To enable this I've written some code to translate ID's. https://github.com/jamiejones85/ESP32VWMITM This code will run on an ESP32 with a can bus transceiver and a MCP2515 SPI can bus.
