Volvo Electronic Throttle Pedal
P80 Platform (850, V70 I, ...)
Electrical Connection
The part number of the 6 pin electrical connector 978151[1], the terminals and seals can be found on Skandix as well[2].
Pin Number | Cable Color | Function | Comment | Range | |||
Idle | Max | Kickdown Max | Comment | ||||
1 | Gray | Idle Switch | 1.17kOhm | Open | Open | Measured to Ground | |
2 | Yellow | Ground | |||||
3 | Blue-Black (two stripes each) | Kickdown Switch | Automatic only | Open | Open | 1.14kOhm | Measured to Ground |
4 | Pink | Upper Potentiometer Tap | 2.23kOhm | 1.63kOhm | 1.48kOhm | Measured to Center Tap | |
5 | White | Center Tap | 1.15kOhm between 4 and 6 | ||||
6 | Brown | Lower Potentiometer Tap | 1.30kOhm | 1.86kOhm | 1.98kOhm | Measured to Center Tap |
Variants and Part Numbers
Part Number | Gearbox | LHD/RHD | Vehicles Used | Comments | Confirmed |
9447135 | Manual | LHD | Diesel only | (should be equal to 9447136) | |
9447136 | Automatic | LHD | Diesel only | yes | |
9447137 | Manual | RHD | Diesel only | (should be equal to 9447136) | |
9447138 | Automatic | RHD | Diesel only | (should be equal to 9447136) |
P2 Platform (V70 II, S60 I, ...)
The P2 platform comes with Ride-by-Wire for all engines.
- ↑ https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/plugs/plug-housing/1034002/ (Backup: Web Archive)
- ↑ Terminal (0.5-1.0mm²): https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/plugs/plug-blade-terminal-sleeve/1034003/ (Backup: Web Archive) Terminal (1.0-2.5mm²): https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/plugs/plug-blade-terminal-sleeve/1034004/ (Backup: Web Archive) Seal (0.5-1.0mm²): https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/fasteners/cable-seal/1034007/ (Backup: Web Archive) Seal (1.0-2.5mm²): https://www.skandix.de/en/spare-parts/accessories/din-assembly-parts/fasteners/cable-seal/1034008/ (Backup: Web Archive)
