joromy_tim_w_GND_fill_15b - Schematic.pdf
TIM connector C4998
Name (New TIM)
Circuit (Old TIM)
Function (New TIM)
1
NC
NC
2
MTMP-
3708 (BN) Motor Temp sensor
Motor Temp sensor Input -
3
DIS_DRV
3404 (YE) Chg cord plugged in
Charge cable plugged in (12V, Motor PWM inhibit when low)
4
USART_TX
3017 (DG/WH) SIADIS RXD
Serial comm. Or WiFi module
5
CAN_H
914 (TN/OG) J1850 bus plus
CAN BUS
6
STOP_RLY
3235 (YE/LG) Stop lamp RLY
Stop signal when regen (Active, GND. Inactive, Z)
7
VSS_OUT
679 (GY/BK) Vehicle speed signal
Vehicle Speed Signal, to IAA and Power steering (12v PWM)
8
SIG_MAIN_C
3986 (DG) Main contactor
DC contactor and oil pump relay (Active, GND. Inactive, Z)
9
12V_ALL_T
276 (BN) Power hot all time
12V all time (used for relay protection diode)
10
12V_RUN_START
640 (RD/YE) Power run/start
12v in RUN, START, ACC
11
MTMP+
3757 (BK/WH) Motor Temp sensor
Motor Temp sensor Input +
12
NC
NC
13
3.3V_USART
3018 (WH) SIADIS d/l
14
USART_RX
3016 (LG/BK) SIADIS TXD
15
CAN_L
915 (PK/LB) J1850 bus minus
CAN BUS
16
NC
NC
17
NC
NC
18
PRECHG_RLY
3991 (TN) Precharge RLY contr
Precharge relay (Active, GND. Inactive, Z)
19
12V_ALL_T
20
12V_RUN_START
12v in RUN, START (this will power up the inverter ECU)
21
NC
NC
22
NC
NC
23
GND_USART
3019 (GY/BK) SIADIS GND
24
NC
NC
25
NC
NC
26
SIG_VSS_B
3701 (DB/WH) VSS B signal
Encoder channel B
27
NC
NC
28
NC
NC
29
GND
3233 (BK/LB) GND
GND
30
5V_VSS
3707 (OG) VSS +12 ref
Encoder PWR +5V
31
CH_GND
57 (BK) Chassis GND
Chassis GND
32
NC
NC
33
NC
NC
34
NC
NC
35
EMCY_PWR
3997 (DG) Emergency PWR Off
EPO Emergency Power Off (Active, Z. Inactive, 12V)
36
SIG_VSS_A
3700 (LB/RD) VSS A signal
Encoder channel A
37
OIL_P_RLY
3005 (VT/LG) Oil pump RLY
38
NC
NC
39
GND
3233 (BK/LB) GND
GND
40
GND_VSS
3659 (BK/PK) VSS GND
Encoder GND
TIM connector C4999
Name (New TIM)
Circuit (Old TIM)
Function (New TIM)
1
NC
224 (TN/WH) ABS fault in
ABS_FAULT (Active, GND. Inactive, 12V)
2
NC
NC
3
GND_APS1
3837 (GY/YE) APS1 GND
Trottle pot GND
4
SIG_APS1
3835 (YE/WH) APS1 Signal
Trottle pot signal
5
5V_APS1
3836 (YE/LB) APS1 +5V
Trottle pot PWR
6
ABS_ACT_IN
491 (OG/LB) ABS active in
ABS input. Limit torque and regen. (Active, 12V. Inactive, GND)
7
GND_DIR_SW
3500 (RD) DTR TR1 Signal
Gear switch GND
8
SW_START
33 (WH/PK) PWR (Hot in start)
Key in start pos (Active, 12V)
9
SW_CRUISE
3011 (BK/OG) APS2 GND
Cruise control switch/button (Active, 12V)
10
SIG_PWR_L
3012 (WH) APS2 Signal
BMS input. Limit torque and regen. (Active, 12V. Inactive, Z)
11
SIG_OIL_PS
3010 (TN) APS2 +5V
Analog/lamp oil P indicator (0-5V/Active, GND. Inactive, Z)
12
OIL_P_SENS
3605 DB/WH) Oil P switch
Analog/switch oil P sensor (0-5V/Active, GND. Inactive, Z)
13
NC
3503 (YE) DTR TR4 Signal
Goes to DTR switch and "old" BCM C1987 pin 18
14
SW_BRAKE
810 (RD/LG) Brake pedal sw
Brake pedal switch (Active, 12V)
15
NC
3014 (BK/WH) APS3 GND
Spare wire
16
5V_OIL_PS
3015 (WH/RD) APS3 Signal
Only if analog 5V oil pressure sensor is used
17
ERROR_OUT
3013 (GY/BK) APS3 +5V
Error output (open collector 0.5A)
18
SW_REV
3502 (DG) DTR TR3A Signal
Cut at DTR switch pin3 and tie to pin11 140 (BK/PK)
19
NC
NC
20
NC
3501 (DB) DTR TR2 Signal
Goes to DTR switch and "old" BCM C1987 pin 17
21
GND_BRK_PS
3601 (WH/RD) Brake P sens
Brake pressure sensor GND
22
PS_BRAKE
3600 (RD/WH) Brake P sens
Brake pressure sensor signal ~ 0.5-5V
23
5V_BRK_PS
3603 (RD) Brake P sens
Brake pressure sensor PWR
24
SW_FWD
3504 (BK/OG) DTR GND
Gear switch (Active, Z. Inactive, GND)
