Schematics and connector pinout
Revision as of 22:25, 23 December 2019 by Joromy (talk | contribs)
joromy_tim_w_GND_fill_15b - Schematic.pdf
TIM connector C4998
Name (New TIM) Circuit (Old TIM) Function (New TIM)
1 NC NC
2 MTMP- 3708 (BN) Motor Temp sensor Motor Temp sensor Input -
3 DIS_DRV 3404 (YE) Chg cord plugged in Charge cable plugged in (12V, Motor PWM inhibit when low)
4 USART_TX 3017 (DG/WH) SIADIS RXD Serial comm. Or WiFi module
5 CAN_H 914 (TN/OG) J1850 bus plus CAN BUS
6 STOP_RLY 3235 (YE/LG) Stop lamp RLY Stop signal when regen (Active, GND. Inactive, Z)
7 VSS_OUT 679 (GY/BK) Vehicle speed signal Vehicle Speed Signal, to IAA and Power steering (12v PWM)
8 SIG_MAIN_C 3986 (DG) Main contactor DC contactor and oil pump relay (Active, GND. Inactive, Z)
9 12V_ALL_T 276 (BN) Power hot all time 12V all time (used for relay protection diode)
10 12V_RUN_START 640 (RD/YE) Power run/start 12v in RUN, START, ACC
11 MTMP+ 3757 (BK/WH) Motor Temp sensor Motor Temp sensor Input +
12 NC NC
13 3.3V_USART 3018 (WH) SIADIS d/l Serial comm. Or WiFi module
14 USART_RX 3016 (LG/BK) SIADIS TXD Serial comm. Or WiFi module
15 CAN_L 915 (PK/LB) J1850 bus minus CAN BUS
16 NC NC
17 NC NC
18 PRECHG_RLY 3991 (TN) Precharge RLY contr Precharge relay (Active, GND. Inactive, Z)
19 12V_ALL_T 276 (BN) Power hot all time 12V all time (used for relay protection diode)
20 12V_RUN_START 640 (RD/YE) Power run/start 12v in RUN, START (this will power up the inverter ECU)
21 NC NC
22 NC NC
23 GND_USART 3019 (GY/BK) SIADIS GND Serial comm. Or WiFi module
24 NC NC
25 NC NC
26 SIG_VSS_B 3701 (DB/WH) VSS B signal Encoder channel B
27 NC NC
28 NC NC
29 GND 3233 (BK/LB) GND GND
30 5V_VSS 3707 (OG) VSS +12 ref Encoder PWR +5V
31 CH_GND 57 (BK) Chassis GND Chassis GND
32 NC NC
33 NC NC
34 NC NC
35 EMCY_PWR 3997 (DG) Emergency PWR Off EPO Emergency Power Off (Active, Z. Inactive, 12V)
36 SIG_VSS_A 3700 (LB/RD) VSS A signal Encoder channel A
37 OIL_P_RLY 3005 (VT/LG) Oil pump RLY DC contactor and oil pump relay (Active, GND. Inactive, Z)
38 NC NC
39 GND 3233 (BK/LB) GND GND
40 GND_VSS 3659 (BK/PK) VSS GND Encoder GND
TIM connector C4999
1 NC 224 (TN/WH) ABS fault in ABS_FAULT (Active, GND. Inactive, 12V)
2 NC NC
3 GND_APS1 3837 (GY/YE) APS1 GND Trottle pot GND
4 SIG_APS1 3835 (YE/WH) APS1 Signal Trottle pot signal
5 5V_APS1 3836 (YE/LB) APS1 +5V Trottle pot PWR
6 ABS_ACT_IN 491 (OG/LB) ABS active in ABS input. Limit torque and regen. (Active, 12V. Inactive, GND)
7 GND_DIR_SW 3500 (RD) DTR TR1 Signal Gear switch GND
8 SW_START 33 (WH/PK) PWR (Hot in start) Key in start pos (Active, 12V)
9 SW_CRUISE 3011 (BK/OG) APS2 GND Cruise control switch/button (Active, 12V)
10 SIG_PWR_L 3012 (WH) APS2  Signal BMS input. Limit torque and regen. (Active, 12V. Inactive, Z)
11 SIG_OIL_PS 3010 (TN) APS2 +5V Analog/lamp oil P indicator (0-5V/Active, GND. Inactive, Z)
12 OIL_P_SENS 3605 DB/WH) Oil P switch Analog/switch oil P sensor (0-5V/Active, GND. Inactive, Z)
13 NC 3503 (YE) DTR TR4 Signal Goes to DTR switch and "old" BCM C1987 pin 18
14 SW_BRAKE 810 (RD/LG) Brake pedal sw Brake pedal switch (Active, 12V)
15 NC 3014 (BK/WH) APS3 GND Spare wire
16 5V_OIL_PS 3015 (WH/RD) APS3 Signal Only if analog 5V oil pressure sensor is used
17 ERROR_OUT 3013 (GY/BK) APS3 +5V Error output (open collector 0.5A)
18 SW_REV 3502 (DG) DTR TR3A Signal Cut at DTR switch pin3 and tie to pin11 140 (BK/PK)
19 NC NC
20 NC 3501 (DB) DTR TR2 Signal Goes to DTR switch and "old" BCM C1987 pin 17
21 GND_BRK_PS 3601 (WH/RD) Brake P sens Brake pressure sensor GND
22 PS_BRAKE 3600 (RD/WH) Brake P sens Brake pressure sensor signal ~ 0.5-5V
23 5V_BRK_PS 3603 (RD) Brake P sens Brake pressure sensor PWR
24 SW_FWD 3504 (BK/OG) DTR GND Gear switch (Active, Z. Inactive, GND)
