Audi A2 Conversion
Revision as of 17:36, 19 February 2022 by Johu (talk | contribs) (ECU)
On this page we describe the conversion of an Audi A2 1.4i petrol to electric propulsion. We will use the following components:
  • Nissan Leaf 24 kWh battery pack with original BMS
  • Toyota Prius Gen 2 (2004-2009) transaxle with matching inverter
  • openinverter Prius Gen2 motor controller
  • openinverter main board running stm32-car (VCU in ECU enclosure)
Pin mapping
We start out by mapping out useful pins of the original wire harness.
The semi-oval connectors are used throughout the engine bay. Numbering scheme: all start with part number 1J09737xx. The last two digits define pin count, arrangement and size. Examples:
  • 1J0973702 - 2 pins, small
  • 1J0973733 - 2x3 pins, large
  • 1J0973703 - 3 pins, small.
  • 1J0973723 - 3 pins, large
  • 1J0973713 - 2x3 pins, small
So the last digits is the number of pins per row, second to last encodes number of rows and pin size. 0=1 row, small; 1=2 rows, small; 2=1 row large, 3=2 rows, large. The matching counterparts have an 8 in place of 7, e.g. 1J09738xx. When the part number ends in a G, the casing is keyed.
ECU
The ECU has two connector slots, a smaller one with pins 82-121 and a larger one with pins 1-81. Here we map out pins useful to us
ECU pinout 1.4i (AUA, BBY)
# orig function our function wire color Engine connector
1,2 GND as is br
3 permanent 12V ro
4 ignition 12V as is ro/sw
5 Lambda (first) heater Reverse light loopback gr 733 1
28 From generator (maybe DF) li/bl
33 Throttle second pot +5V as is gr/ge
34 Throttle second pot (signal) as is br/gn
35 Throttle first pot (signal) as is ge/bl
36 Throttle first pot +5V as is br/ro
38 To cruise control switch * if installed ws
39 Clutch pedal sensor * if installed ro/ge
40/41 To Climate control display sw/ge sw/gr
43/54 To instrument cluster (function unknown) gn/sw bl/ws
51/52 Lambda (first) signal CAN for Prius bl/ws ge 733 6/3
55/56 Brake light switch NC/NO to +12V ws/ro ro/sw
57 To cruise control switch * if installed bl/ro
58/60 CAN-L CAN-H as is or/br or/sw
63 Lambda (second) heater li/ro
64 Charcoal filter solenoid vacuum pump GND bl/ge 722G moved to 722
65 Fuel pump relay- control ro/br
68/69 Lambda (second) signal bl/br ro/li
70/71 Lambda (first) signal dcsw (70), prec (71) bl sw 733 5/4
72 Throttle second pot GND as is gr
73 Throttle first pot GND ge/li
75/76 To cruise control switch * bl/sw sw/ro
82 Engine speed sensor gr/br
85 Intake manifold Temp/Pressure brake vacuum gr 704
86 Hall sender G40 signal ro/sw
87 Engine speed sensor gn/sw
88/89
96/97
Injector 1-4 sw/li li/sw
br/bl sw/gn
83/84
91/92
117/118
Throttle body senror
Throttle body sensor
Throttle body motor
LIN for A/C (83)
charge(91)
ro/gn gn/bl
ro/bl li/ro
gn br/sw
713
2/4, 6/1, 3/5
93 Coolant temp sensor gr/ws
98 +5V wiring to engine bay as is gn/li 704
99 Knock sensor ws
100
114
EGR pot
EGR mot
fake oil pressure
Fake engine oil
br/li
li/ge
1J0973713G
6/5
102/103 Ignition coil bank 1/2 gn/ws gn/ro
106 Knock sensor br
108 GND for engine sensors as is gr/ro
109 Intake manifold Temp/Pressure bl/gn
ECU pinout 1.6FSI
# Org Function Ours Color
1/2 GND br br
3/5 permanent 12V gn/ge gn/ge
4/20/21
39/40
First Lambda ge ro/ge bl/ge
br/ge li/gr
6 N290 Fuel metering valve ro/bl
7 Fuel pump relay control ro/br
8/10 CAN-H CAN-L or/sw or/br
11/16/31
32/50
NOX controller sw br/ws bl
ws/sw ge/ro
12 Heater output switch ge/br
13/17/30 Air mass meter gr/ro gr/ws li/ws
14 Thermo-switch for coolant circulation ro/ws
15/18/43
33/19/24
Throttle POT1/2 (signal/Gnd/+5) ge/li br/ro ge/li
br/gn gr/ge gr
23/46 Climate cotroler sw/gr sw/ge
26/45 Radiator fan controller sw/ge ge/gr
35 EGT ro/gn
36 Brake vaccum sensor bl/br
37 Sensors GND ge/bl
48/57 Brake light switch NO/NC ro/sw ws/ro
42 +5V to sensors ge/gn
49/51/52/55 Cruise control switch * If installed bl/sw ws sw/ro bl/ro
53 To airbag ECU ws/bl
59 Instrument cluster gn/sw
60/80 NOX heater br/ws br/ws
62/64 Current supply relay ro gr/ro
65 Generator DF li/br
67 Clutch pedal switch * if fitted ro/ge
78 N79 crankcase breather heater br
81/100/101
108/109
Coils ro/sw ro/bl ge/gn
ge/bl gn/ge
82/90 G28 Engine speed sensor gr/br gr/ro
83 G40 Hall sender br/bl
84 G71 Intake manifold pressure sens ge/ro
85/87/96 EGR sensor + motor li/gr li/ws ro/ws
86 Coolant temp sensor gr/ws
88 N316 Intake manifold flap valve li/ge
89 F265 Controlled cooling thermostat ro/br
91 G336 Intake flap potentiometer ge/ro
94 G247 Fuel pressure sensor gr
99 +5V to sensors li/ro
105 N205 Inlet Camsh. timing valve li/gn
113 N276 Fuel pressure regulating valve gn/bl
92/93102
107/118/121
Throttle body li/ge li/gr ws
ro/gn ro/bl li
103/110/111 Knock sensor br br ws
106 Sensor gnd in engine bay gr/gn
114/115
116/117
119/120
Injectors 1-4 br/ge br/ws
br/gn br/ro
br/bl br/sw
Silence errors
After disconnecting the engine and removing the ECU we have 3 errors: Low coolant level, low oil, ABS/ESP. Coolant level can be silenced by simply shorting out the corresponding sense pins. We will use the coolant reservoir of the Prius inverter. We might insert a sensor for super neat integration, but not for now.
Low oil can only be cured by supplying the required signal: https://wiki.a2-freun.de/wiki/index.php/G266_-_Geber_f%C3%BCr_%C3%96lstand_und_%C3%96ltemperatur
It's a kind of PWM. We will connect it to a timer pin of the our VCU and try to fake it.
