Audi A2 Conversion
On this page we describe the conversion of an Audi A2 1.4i petrol to electric propulsion. We will use the following components:
- Nissan Leaf 24 kWh battery pack with original BMS
- Toyota Prius Gen 2 (2004-2009) transaxle with matching inverter
- openinverter Prius Gen2 motor controller
- openinverter main board running stm32-car (VCU in ECU enclosure)
Pin mapping
We start out by mapping out useful pins of the original wire harness
ECU
The ECU has two connector slots, a smaller one with pins 82-121 and a larger one with pins 1-81. Here we map out pins useful to us VAG wire color codes:
| # | orig function | our function | wire color |
| 1,2 | GND | ||
| 3 | permanent 12V | ro | |
| 4 | ignition 12V | ||
| 28 | From generator (maybe DF) | li/bl | |
| 65 | Fuel pump relay- control | ro/br |
