VW Hybrid Battery Packs
Revision as of 23:52, 10 February 2021 by Rstevens81 (talk | contribs) (Using Multiple Packs: added some description, needs tidying)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Passat GTE
Module Weight
BMS Board
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
INSERT
Resistor Pic
Fuse
Error creating thumbnail: File with dimensions greater than 12.5 MP
Shunt
Control Board
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
Currently NO Turn Key solutions exist for using more than 1 pack, however ....
The next release of SIMP BMS (assuming to be V3) shall use a teensy 4 which will have 3 canbuses however this is in the early stages of development.
It could be possible to use 2 sets of SIMPBMS however they would exist on 2 separate can buses, this would not to be easy task to implement.
It could be possible to translate the CAN id's from the second pack by using a can in the middle device and still use a single SIMPBMS however this has never been tested.
This is due to the fact that the can id's outputted from the modules are fixed, the ranges used are from 01B0 to 01CE (432-462). If these CAN id's were translated (from the second pack) using a can in the middle device to id's to a range like 01D0 to 01EE (464-494) a single SIMPBMS could be used as there is an undocumented code allowing for extended id's.
    ///////////////// one extender increment//////////
    case (0x1D0):
      CMU = 9;
      Id = 0;
      break;
    case (0x1D1):
      CMU = 9;
      Id = 1;
      break;
    case (0x1D2):
      CMU = 9;
      Id = 2;
      break;
    case (0x1D4):
      CMU = 10;
      Id = 0;
      break;
    case (0x1D5):
      CMU = 10;
      Id = 1;
      break;
    case (0x1D6):
      CMU = 10;
      Id = 2;
      break;
    case (0x1D8):
      CMU = 11;
      Id = 0;
      break;
    case (0x1D9):
      CMU = 11;
      Id = 1;
      break;
    case (0x1DA):
      CMU = 11;
      Id = 2;
      break;
    case (0x1DC):
      CMU = 12;
      Id = 0;
      break;
    case (0x1DD):
      CMU = 12;
      Id = 1;
      break;
    case (0x1DE):
      CMU = 12;
      Id = 2;
      break;
    case (0x1E0):
      CMU = 13;
      Id = 0;
      break;
    case (0x1E1):
      CMU = 13;
      Id = 1;
      break;
    case (0x1E2):
      CMU = 13;
      Id = 2;
      break;
    case (0x1E4):
      CMU = 14;
      Id = 0;
      break;
    case (0x1E5):
      CMU = 14;
      Id = 1;
      break;
    case (0x1E6):
      CMU = 14;
      Id = 2;
      break;
    case (0x1E8):
      CMU = 15;
      Id = 0;
      break;
    case (0x1E9):
      CMU = 15;
      Id = 1;
      break;
    case (0x1EA):
      CMU = 15;
      Id = 2;
      break;
    case (0x1EC):
      CMU = 16;
      Id = 0;
      break;
    case (0x1ED):
      CMU = 16;
      Id = 1;
      break;
    case (0x1EE):
      CMU = 16;
      Id = 2;
      break;
    ///////////////////////standard ids////////////////
    case (0x1B0):
      CMU = 1;
      Id = 0;
      break;
    case (0x1B1):
      CMU = 1;
      Id = 1;
      break;
    case (0x1B2):
      CMU = 1;
      Id = 2;
      break;
    case (0x1B4):
      CMU = 2;
      Id = 0;
      break;
    case (0x1B5):
      CMU = 2;
      Id = 1;
      break;
    case (0x1B6):
      CMU = 2;
      Id = 2;
      break;
    case (0x1B8):
      CMU = 3;
      Id = 0;
      break;
    case (0x1B9):
      CMU = 3;
      Id = 1;
      break;
    case (0x1BA):
      CMU = 3;
      Id = 2;
      break;
    case (0x1BC):
      CMU = 4;
      Id = 0;
      break;
    case (0x1BD):
      CMU = 4;
      Id = 1;
      break;
    case (0x1BE):
      CMU = 4;
      Id = 2;
      break;
    case (0x1C0):
      CMU = 5;
      Id = 0;
      break;
    case (0x1C1):
      CMU = 5;
      Id = 1;
      break;
    case (0x1C2):
      CMU = 5;
      Id = 2;
      break;
    case (0x1C4):
      CMU = 6;
      Id = 0;
      break;
    case (0x1C5):
      CMU = 6;
      Id = 1;
      break;
    case (0x1C6):
      CMU = 6;
      Id = 2;
      break;
    case (0x1C8):
      CMU = 7;
      Id = 0;
      break;
    case (0x1C9):
      CMU = 7;
      Id = 1;
      break;
    case (0x1CA):
      CMU = 7;
      Id = 2;
      break;
    case (0x1CC):
      CMU = 8;
      Id = 0;
      break;
    case (0x1CD):
      CMU = 8;
      Id = 1;
      break;
    case (0x1CE):
      CMU = 8;
      Id = 2;
      break;
