VW Hybrid Battery Packs
Revision as of 22:14, 10 February 2021 by Rstevens81 (talk | contribs) (Golf GTE: corrected incorrect voltage on fuse)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Cooling
Contactors/Pre Charge
Passat GTE
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
Using Multiple Packs
