VW Hybrid Battery Packs
Revision as of 12:14, 9 February 2021 by Bigpie (talk | contribs)
Specification Overview
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
BMS
Battery Modules
Cooling
Contactors/Pre Charge
