Anyway, I have a 2008 Proton Jumbuck and a 2014 Nissan eNV200 that I intend to meld together, my original intent going into this project was "Yeah I'll just pull the motor and batteries, plug them together, grab an aftermarket ECU, wire that up, tick some boxes on some software like any other engine swap, get the tick in the box from the certifier and she'll be right"
Yeah, don't think it will be that simple, I've searched high and low and everywhere in between until I stumbled upon this project.
Anyways, I've been playing with combustion engines for years, however considering it now costs me $120 a fortnight to drive to work and back, and the fact that I have plentiful electrickery falling from the sky and being collected by my solar panels, I am generally getting around $40/month back from the electrickery provider. Sweet.
Anyways, when I came across the Nissan Leaf Gen2 Board at https://openinverter.org/wiki/Nissan_Leaf_Gen2_Board I was wondering will this work in the eNV200? Does this mean I can swap out this board, wire the stuff in that I need to, and then just hit the key and off I go?
- I currently DO NOT have an electronic throttle, can I set this up to just use any throttle I want?
- Although I do not technically need to by law, it's been heavily suggested to me elsewhere that when Regen activates, that I set this up for the brake lights to come on, is this board capable of doing so?
- The recipient car is not a push button car, it's a key, how does this board activate/deactivate? Is it a simple "Key to On, wait for 20 seconds, and go" or is it able to be "Key to on, count to 5, hit start to join the main contactors, then drive"?
- Can this board drive gauges/instrument cluster, or will I have to come up with another way of doing so? I'm not sure 100% on what data feeds to where with what. Most of the stuff in this recipient car is mechanical or "Dumb" electric (Whereby it's voltages and resistances), so a new dash will be required.
But I'm getting ahead of myself here.
I also note that the product page says:
Was this with any special programming? Or is it a straight up bolt in and off you go thing?This replacement board has been reported to achieve 136kW with the stock hardware and achieves a 0-100 time of 6.7s in a Toyota GT86
Sorry if this is a lot of poorly phrased questions or if I haven't looked everywhere, my brain is a tad fried at the moment from reading bucketloads of stuff everywhere else and I've managed to get myself a bit mixed up with who does what and how "Plug and Play" the solution is.
Thanks in advance everyone!
