Does Prius gas pedal contain electronics
FFMan
Has thanked: 9 times
Been thanked: 50 times
Post by FFMan »
The wiki says power it with 5v, but I'm using a 3.3v Teensy.
Does the pedal contain electronics that need 5v, or is just a pair of pots with gnd and vcc across the resistor ?
I can scale the return to 3.3v, but i'd rather not if its not required and i can use 3.3v across it.
Has thanked: 328 times
Been thanked: 847 times
Re: Does Prius gas pedal contain electronics
Try it. I would for sure have input protection for anything going into a micro controller anyway.
A voltage divider and zener is a good start.
Has thanked: 91 times
Been thanked: 517 times
You not using a ready designed board/vcu?
FFMan
Post by FFMan »
Nope. Re using one I made for the last project. It’s easy with the phev inverter as you only need to send it one number over can.
Also I want to tune the regen and add eco mode and speed limiting etc
