Bench test - Leaf with OI board (v3) and zombieverter. Spins a bit then stops until manual intervention
- Has thanked: 545 times
- Been thanked: 153 times
So I've got my bench setup spinning but wondering why after a few spins, it stops responding. The inverter whines louder but no spin until I turn the shaft by hand then it spins again for a bit.
I'm sure it's my params (to follow shortly...)
Any ideas on the likely culprit?
Re: Bench test - Leaf with OI board (v3) and zombieverter. Spins a bit then stops until manual intervention
Params attached for both Zombie and OI
- 2.31TH-Zom-params.json
- (2.26 KiB) Downloaded 459 times
- 2.31TH-OI-params.json
- (1.53 KiB) Downloaded 468 times
Any idea on this? It's as if the motor position is lost and the manual intervention (rotating the shaft by hand) allows it to "find" it again.
Anyone able to provide insight into what might be causing this? The bench setup is not setup atm as I'm focusing on other aspects but I'll need to address this in the coming months.
Failing that I'll swap back to the original leaf board but I'd rather be rolling the OI board if possible.
zippy500
- Has thanked: 100 times
- Been thanked: 7 times
any update on this? I'm thinking of taking this route.
- Has thanked: 330 times
- Been thanked: 847 times
It is all down to the inverter tuning. Get that working first. Zombie has no part in this.
Yes I was thinking so, was hoping someone might have insight or suggestions on what params might cause such behaviour on the OI side, but cheers for the response...
Good point. I think I was using one based on Johus setup. I'll have a look at the other settings on there and see if that helps.tom91 wrote: ↑Thu May 22, 2025 3:41 pm https://openinverter.org/parameters/ https://openinverter.org/parameters/view.html?id=26
Whos is this?
Cheers
- Been thanked: 1918 times
No idea but it is not legit. Will remove or disable them.tom91 wrote: ↑Thu May 22, 2025 3:41 pm https://openinverter.org/parameters/ https://openinverter.org/parameters/view.html?id=26
Whos is this?
Please DO NOT use!
Any idea on what to look at in the params or which ones to use?
Find one Johu has recently attached to a post here and that'll probably get you like 95% of the way there. Remember you'll have to tune your individual resolver offset no matter which one you use.
I've tuned the offset and I'm fairly certain I was using Johus params from his touran thread. I'll revisit though when I clear some space on my bench.
