Bench test - Leaf with OI board (v3) and zombieverter. Spins a bit then stops until manual intervention
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
So I've got my bench setup spinning but wondering why after a few spins, it stops responding. The inverter whines louder but no spin until I turn the shaft by hand then it spins again for a bit.
I'm sure it's my params (to follow shortly...)
Any ideas on the likely culprit?
Re: Bench test - Leaf with OI board (v3) and zombieverter. Spins a bit then stops until manual intervention
Params attached for both Zombie and OI
2.31TH-Zom-params.json
(2.26 KiB) Downloaded 462 times
2.31TH-OI-params.json
(1.53 KiB) Downloaded 471 times
Any idea on this? It's as if the motor position is lost and the manual intervention (rotating the shaft by hand) allows it to "find" it again.
Anyone able to provide insight into what might be causing this? The bench setup is not setup atm as I'm focusing on other aspects but I'll need to address this in the coming months.
Failing that I'll swap back to the original leaf board but I'd rather be rolling the OI board if possible.
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
any update on this? I'm thinking of taking this route.
Has thanked: 330 times
Been thanked: 847 times
It is all down to the inverter tuning. Get that working first. Zombie has no part in this.
tom91 wrote: Thu May 22, 2025 2:14 pm It is all down to the inverter tuning.
Yes I was thinking so, was hoping someone might have insight or suggestions on what params might cause such behaviour on the OI side, but cheers for the response...
Good point. I think I was using one based on Johus setup. I'll have a look at the other settings on there and see if that helps.
Cheers
No idea but it is not legit. Will remove or disable them.
Please DO NOT use!
johu wrote: Sat May 24, 2025 2:44 pm Please DO NOT use!
Any idea on what to look at in the params or which ones to use?
Zieg
Has thanked: 168 times
Been thanked: 160 times
Post by Zieg »
Find one Johu has recently attached to a post here and that'll probably get you like 95% of the way there. Remember you'll have to tune your individual resolver offset no matter which one you use.
Zieg wrote: Sun May 25, 2025 11:50 pm Find one Johu has recently attached to a post here and that'll probably get you like 95% of the way there. Remember you'll have to tune your individual resolver offset no matter which one you use.
I've tuned the offset and I'm fairly certain I was using Johus params from his touran thread. I'll revisit though when I clear some space on my bench.
