Electric Oil Pump Recommendations
Eagle411
Has thanked: 5 times
Been thanked: 7 times
Post by Eagle411 »
Does anyone have a source for a transmission agnostic electric oil pump? Am I wrong in thinking that these hybrid transmissions could using an external pump as apposed to their OEM pump? I just need to close off the opening where the OEM pump attached.
Has thanked: 328 times
Been thanked: 847 times
Re: Electric Oil Pump Recommendations
Please provide details, are you on about the Lexus GS450h?
Kelju
Has thanked: 13 times
Been thanked: 19 times
Post by Kelju »
If you are indeed talking about the GS450h, at least there is this adapter available:
https://www.ebay.com/itm/175936880476?m ... media=COPY
This would indicate that other people are having similar ideas and I have also thought about the replacement of the OEM pump. Sorry to say, but I have not yet found a suitable replacement.
Has thanked: 91 times
Been thanked: 517 times
https://www.ebay.co.uk/itm/204855182822 I used one of these to circulate oil for my outlander motor. Bolted a plate to it and tapped a couple of holes for threaded barbs.
No idea if it's suitable for your desired application
