Electric Oil Pump Recommendations
Does anyone have a source for a transmission agnostic electric oil pump? Am I wrong in thinking that these hybrid transmissions could using an external pump as apposed to their OEM pump? I just need to close off the opening where the OEM pump attached.
- Has thanked: 209 times
- Been thanked: 576 times
- Has thanked: 13 times
- Been thanked: 18 times
Re: Electric Oil Pump Recommendations
If you are indeed talking about the GS450h, at least there is this adapter available:
https://www.ebay.com/itm/175936880476?m ... media=COPY
This would indicate that other people are having similar ideas and I have also thought about the replacement of the OEM pump. Sorry to say, but I have not yet found a suitable replacement.
- Has thanked: 83 times
- Been thanked: 428 times
https://www.ebay.co.uk/itm/204855182822 I used one of these to circulate oil for my outlander motor. Bolted a plate to it and tapped a couple of holes for threaded barbs.
No idea if it's suitable for your desired application
