I'm new and learning. FDU question
ducttape
Post by ducttape »
I happen to have a Model S front drive unit and have been noodling a project with it. I read that it can only be run as slave but I see some comments here that imply that it can be run with the RDU board as a single motor.
Can someone clear this up for me?
Has thanked: 380 times
Been thanked: 1571 times
Re: I'm new and learning. FDU question
Hi and welcome!
It will run with this board: https://openinverter.org/shop/index.php ... duct_id=62
ducttape
Post by ducttape »
Thanks much!
I still have a lot to learn but this is encouraging.
Has thanked: 238 times
Been thanked: 278 times
Post by P.S.Mangelsdorf »
To further illuminate:
Pre 2017-ish, Tesla had a pretty clear set of drive units. There were two basic architectures, dubbed Large and Small, and each had two variants. The Large had a Base and Sport, and the Large was only ever used in the rear of the S/X. The Larges were the same externally, with different inverter internals. The Small had Front and Rear. The Smalls have different external cases, but similar/the same internals.
Check out these parts of the Wiki:
https://openinverter.org/wiki/Category:Tesla (Scroll down for chart on drive units)
https://openinverter.org/wiki/Tesla_Mod ... %22SDU%22)
Post 2017-ish, things seem to get a bit confusing as they began integrating the Model 3 style drive units into the Model S/X. I have not yet seen a good outline of when and what motors went into the S/X in recent years. It's probably something we need to work on.
