Zombieverter looses WiFi connection when trying to update
- Has thanked: 545 times
- Been thanked: 153 times
A friend asked me to check their zombieverter with my bench setup, all checked and fine but it is still on version 2.04. when I try to update it by swd UART update, the binary file uploads but the connection drops and it doesn't complete the update.
- Has thanked: 329 times
- Been thanked: 847 times
Re: Zombieverter looses WiFi connection when trying to update
its not swd update... this is covered many times in videos and the forum
You need the other update.
Sorry thats my memory, I was trying via UART not SWD and it was failing.
- Been thanked: 1914 times
The latest web ui hides SWD update as it only works with additional connections. And even then it never really worked for me
UART may fail but in that case you can power cycle and retry
I was never sure but will the latest web UI work on zombie?
I did try power cycling several times but the behaviour was the same, it says upload complete, but then doesn't do anything and the WiFi connection drops.
nkiernan
- Has thanked: 516 times
- Been thanked: 95 times
Yep, it works and is a good job. I recently made up some ESP8266 wemos adaptors and have tested the new UI on two ZV's. also tried an ESP32 based wifi module but haven't got that version working yetJacobsmess wrote: ↑Wed May 08, 2024 6:28 pm I was never sure but will the latest web UI work on zombie?
peterdiffey
- Has thanked: 6 times
- Been thanked: 6 times
I have been suffering the same issue. I have been struggling with the issues for several days. I was getting the progress bar stopping at regular intervals. I was still able to ping the VCU.
I think I have now solved the problem.
Disconnect the Canbus, this instantly fixed my problem. I think canbus messages have higher priority than all other and are stopping the firmware reload.
Pete
That's indeed very odd. The boot loader just listens to ID 0x7DD all other messages are ignored on hardware level and don't generate interrupts.
Do you have 7DD on the bus?
Sorry I should have updated this. I managed to get it to work by reflashing the wemos SPIFFS via Arduino IDE with the newly updated web interface, this allowed zombieverter to be updated after.
