Zombieverter looses WiFi connection when trying to update
Has thanked: 545 times
Been thanked: 153 times
Post by Jacobsmess »
A friend asked me to check their zombieverter with my bench setup, all checked and fine but it is still on version 2.04. when I try to update it by swd UART update, the binary file uploads but the connection drops and it doesn't complete the update.
Has thanked: 330 times
Been thanked: 847 times
Re: Zombieverter looses WiFi connection when trying to update
its not swd update... this is covered many times in videos and the forum
You need the other update.
tom91 wrote: Wed May 08, 2024 1:38 pm its not swd update... this is covered many times in videos and the forum
Sorry thats my memory, I was trying via UART not SWD and it was failing.
Been thanked: 1914 times
The latest web ui hides SWD update as it only works with additional connections. And even then it never really worked for me :(
UART may fail but in that case you can power cycle and retry
johu wrote: Wed May 08, 2024 6:22 pm The latest web ui hides SWD update as it only works with additional connections.
I was never sure but will the latest web UI work on zombie?
johu wrote: Wed May 08, 2024 6:22 pm UART may fail but in that case you can power cycle and retry
I did try power cycling several times but the behaviour was the same, it says upload complete, but then doesn't do anything and the WiFi connection drops.
nkiernan
Has thanked: 516 times
Been thanked: 95 times
Post by nkiernan »
Jacobsmess wrote: Wed May 08, 2024 6:28 pm I was never sure but will the latest web UI work on zombie?
Yep, it works and is a good job. I recently made up some ESP8266 wemos adaptors and have tested the new UI on two ZV's. also tried an ESP32 based wifi module but haven't got that version working yet
peterdiffey
Has thanked: 6 times
Been thanked: 6 times
Post by peterdiffey »
I have been suffering the same issue. I have been struggling with the issues for several days. I was getting the progress bar stopping at regular intervals. I was still able to ping the VCU.
I think I have now solved the problem.
Disconnect the Canbus, this instantly fixed my problem. I think canbus messages have higher priority than all other and are stopping the firmware reload.
Pete
That's indeed very odd. The boot loader just listens to ID 0x7DD all other messages are ignored on hardware level and don't generate interrupts.
Do you have 7DD on the bus?
Sorry I should have updated this. I managed to get it to work by reflashing the wemos SPIFFS via Arduino IDE with the newly updated web interface, this allowed zombieverter to be updated after.
