I am installing a Leaf drive unit to a Peugeot 106 Electrique.
The speedo used to be powered by a sensor sensing the teeth on a gear on the original drive motor.
Does the Zombieverter have a configurable RPM output using the PWM or alternatively an analogue output where I could drive an analogue to frequency converter.
Calibrated RPM from PWM output on Zombieverter VCU for speed
Re: Calibrated RPM from PWM output on Zombieverter VCU for speed
I would like drive a digital speedo to.
have you had any answer or have you do it another way?
- Has thanked: 330 times
- Been thanked: 848 times
The BMW E39 vehicle class has an engine rpm digital output. It is not configurable right now but this can be added in the future.
