Calibrated RPM from PWM output on Zombieverter VCU for speed
Rustybkts
Has thanked: 17 times
Been thanked: 11 times
Post by Rustybkts »
I am installing a Leaf drive unit to a Peugeot 106 Electrique.
The speedo used to be powered by a sensor sensing the teeth on a gear on the original drive motor.
Does the Zombieverter have a configurable RPM output using the PWM or alternatively an analogue output where I could drive an analogue to frequency converter.
snelly1
Re: Calibrated RPM from PWM output on Zombieverter VCU for speed
Post by snelly1 »
I would like drive a digital speedo to.
have you had any answer or have you do it another way?
Has thanked: 330 times
Been thanked: 847 times
The BMW E39 vehicle class has an engine rpm digital output. It is not configurable right now but this can be added in the future.
