REAR SDU what lubricant and how much?
espriev
Post by espriev »
Sorry if this has been covered, my searching does not find it!
I can find it for Model 3, model S, FRONT SDU...
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Re: REAR SDU what lubricant and how much?
Post by Boxster EV »
viewtopic.php?f=10&t=84
Google also found this, but check it’s validity from the manuals above:
Front drive unit part number 1035000-00-F and earlier: Mobil SHC 629
Front drive unit part number 1035000-00-J and later: DEXRON VI (DEXRON 6) automatic transmission fluid
Rear drive unit (small and large): DEXRON VI (DEXRON 6) automatic transmission fluid
Component / System Capacity
Transmission (front, small drive unit) 1.8 quarts 1,750 ml
Transmission (rear, small drive unit) 2.4 quarts 2,250 ml
Transmission (rear, large drive unit) 1.5 quarts 1,400 ml
catphish
Has thanked: 99 times
Been thanked: 197 times
Post by catphish »
See also my thread here. This is specifically about the 1035000-00-F and earlier SDU which requires Mobil SHC 629
viewtopic.php?p=53390
