Sorry if this has been covered, my searching does not find it!
I can find it for Model 3, model S, FRONT SDU...
REAR SDU what lubricant and how much?
- Boxster EV
- Has thanked: 57 times
- Been thanked: 50 times
Re: REAR SDU what lubricant and how much?
viewtopic.php?f=10&t=84
Google also found this, but check it’s validity from the manuals above:
Front drive unit part number 1035000-00-F and earlier: Mobil SHC 629
Front drive unit part number 1035000-00-J and later: DEXRON VI (DEXRON 6) automatic transmission fluid
Rear drive unit (small and large): DEXRON VI (DEXRON 6) automatic transmission fluid
Component / System Capacity
Transmission (front, small drive unit) 1.8 quarts 1,750 ml
Transmission (rear, small drive unit) 2.4 quarts 2,250 ml
Transmission (rear, large drive unit) 1.5 quarts 1,400 ml
- catphish
- Has thanked: 99 times
- Been thanked: 197 times
See also my thread here. This is specifically about the 1035000-00-F and earlier SDU which requires Mobil SHC 629
viewtopic.php?p=53390
