Porsche canbus dbc files
- EV_Builder
- Has thanked: 16 times
- Been thanked: 34 times
Ok basically in need of any dbc file you have or can find from any Porsche.
Trying to shed some light on the mysteries on my Panamera 970...
- EV_Builder
Re: Porsche canbus dbc files
nobody anything?
i thought that i saw some porsches converted on here? How do you guys have the ABS unit happy?
There's one in the Zero EV build thread.EV_Builder wrote: ↑Tue Aug 10, 2021 12:26 pm nobody anything?
viewtopic.php?p=3714#p3714
My Porsche (2000 986) has minimal CAN and the ABS works fine as it is. I want to switch the cluster out for a CAN one though.
- EV_Builder
thank u very much for your response!
- Has thanked: 106 times
- Been thanked: 229 times
Best thing to do would be look if someone engineswapped one and reach out to them.
Thanks how I found the boxster canbus info. However the boxsters are very very crude and the ABS system is mainly standalone.
- EV_Builder
Do you have it? Can you share?
- EV_Builder
Ok guys! I'm like in maniac mode = on now!
Look at this: I build-ed further on my CANBus suite so now it accepts 3 Adapters (USB peaks) and i can play with stuff.
The ID list you see is coming from that particular interface.
underwater i re-join (or not) the canbusses again by software (forwarding messages).
@Damian; I also made a very nice CANBus Log comparer...maybe i pull that part out one day and release it to the open...
! = Unique value in this side
RED = Different then other side
- EV_Builder
In action injecting my own data:
Does the .dbc contain data for individual wheel speed off the ABS system? I believe it uses the same style as the E46M3, which is common as a standalone motorsport integration. Im interested in possibly using the Boxster version as the dynamics are likely programmed closer to my needs in terms of vehicle weight distribution. Id like to pull wheel speed data and integrate that into traction control.
I have the E46M3 data, but havent delved into the Porsche stuff.
- EV_Builder
If you mean the Porsche DBC from internet: yes.
In my car I have never driven it yet so no moving captures yet.BO_ 680 WheelSpeeds: 8 Vector__XXX
SG_ WheelSpeedRR : 48|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedLR : 32|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedRF : 16|16@1+ (1,0) [0|65535] "" Vector__XXX
SG_ WheelSpeedLF : 0|16@1+ (1,0) [0|65535] "" Vector__XXX
Hi ,
I got some battery modules from a cayenne (Bosch 13s 48 volt) , they have canbus.
Do you think it is possible to get data from it through CAN ?
https://transistor-man.com/PhotoSet/doo ... iagram.jpg
Would be great for home storage.....
Thanks Rod
Thanks Rod
