Antispinn system
Majshumlan
Antispinn system
Post by Majshumlan »
Hi
Im looking into doin a EV build with Tesla Large Drive/Opensource Inverter and are wondering
if/how any one have done a antispinn system?
Is it done by using a second cpu I/O unit reading wheel encoders and controlling the throttle by the CAN bus?
Best regards
Has thanked: 75 times
Been thanked: 696 times
Re: Antispinn system
I believe ZeroEV offer this for their commercial system:
https://zero-ev.co.uk/
johnspark
Has thanked: 59 times
Been thanked: 48 times
Post by johnspark »
Zero-ev costs look reasonable...
Has thanked: 263 times
Been thanked: 716 times
The Zero-EV system runs all within the inverter control board.
nailgg
Post by nailgg »
tom91 wrote: Tue Jul 02, 2019 8:42 am The Zero-EV system runs all within the inverter control board.
So they are probably using a secondary processor on their control board for sensing the wheel speed. Maybe something that acts as a man-in-the-middle between the throttle input and the main inverter mcu. I think they don't like to share how they are doing this? That's not "open inverter" anymore :)
nailgg wrote: Tue Jul 02, 2019 6:20 pm That's not "open inverter" anymore :)
Correct, after having helped develop the Open-Inverter solution to the point where it is now certain features were introduced and developed in software and hardware that are specific to the Zero-EV solution and regarded as unique selling points.
Majshumlan
Ok,thanx for the answers!
I think I look into using a CR0032 as a processor for this.
Comparing wheel encoders and maby steering angle and let the sum of this control the throttle.
I would like to be able to have diffrent selectable driving modes also .Plus I could use the processor for alot more
Kevin Sharpe
Been thanked: 9 times
Post by Kevin Sharpe »
Majshumlan wrote: Wed Jul 03, 2019 8:46 amI think I look into using a CR0032 as a processor for this.
Or you could look into starting a crowdfunder to commission Johannes (or someone else) to write the open source traction control software for the Tesla inverter boards. In that way we all contribute and benefit from the development 8-)
Depends on your end goal... if you need a supported and warranted solution then buy from Zero EV today... if you are happy with community development and support then open source may be the answer :)
