Not sure where to put this bus as I’m using a mish mash of parts I wonder if anyone has the thermistor values for Tesla model S at set temperatures. Degrees Celsius
Chevy Volt
-40 75.5k
-20 22.5k
0 7.2k
20 2.7k
40 1.2k
60 0.5k
80 0.3k
100 0.16k
Chrysler Pacifica
To be added to.....
0 31.1k
20 10.9k
Thermistor values.
Re: Thermistor values.
Taking into account my guess of the temp in my apartment and my down and dirty Multimeter I think it’s safe to assume they are 10k ohm thermistors so should work on the Tesla boards nicely, finally something’s working out right.
If somethings worth doing, its worth getting it wrong a few times first.
- Has thanked: 166 times
- Been thanked: 411 times
Here is the Volt inverter IGBT datasheet. On the last page you can see the temp profile.
mbb600tv6a.pdf- (823.73 KiB) Downloaded 241 times
