Thermistor values.
x.l.r.8
Thermistor values.
Post by x.l.r.8 »
Not sure where to put this bus as I’m using a mish mash of parts I wonder if anyone has the thermistor values for Tesla model S at set temperatures. Degrees Celsius
Chevy Volt
-40 75.5k
-20 22.5k
0 7.2k
20 2.7k
40 1.2k
60 0.5k
80 0.3k
100 0.16k
Chrysler Pacifica
To be added to.....
0 31.1k
20 10.9k
If somethings worth doing, its worth getting it wrong a few times first.
x.l.r.8
Re: Thermistor values.
Post by x.l.r.8 »
Taking into account my guess of the temp in my apartment and my down and dirty Multimeter I think it’s safe to assume they are 10k ohm thermistors so should work on the Tesla boards nicely, finally something’s working out right.
Been thanked: 411 times
x.l.r.8 wrote: Fri Apr 19, 2019 8:12 am Taking into account my guess of the temp in my apartment and my down and dirty Multimeter I think it’s safe to assume they are 10k ohm thermistors so should work on the Tesla boards nicely, finally something’s working out right.
Here is the Volt inverter IGBT datasheet. On the last page you can see the temp profile.
mbb600tv6a.pdf
(823.73 KiB) Downloaded 242 times
