Tool chain
EV_Builder
Tool chain
Post by EV_Builder »
I was wondering which toolchain is needed to compile the code for the inverter?
Perhaps elaborate on it and make this a sticky.
Then we are a small step closer to participating :)
Been thanked: 1913 times
Re: Tool chain
It is in the readme and I think thats where it belongs: https://github.com/jsphuebner/stm32-sine (scroll to bottom)
EV_Builder
Re: Tool chain
Yeah, i found it but to me it doesn't make sense. But i deff can code, so perhaps there is way to lower the bar. When i got my environment setup i will post it here. If i succeed that is...
EV_Builder
Re: Tool chain
Until now:
I know the libs are on github so will pull them but i dont know where the my is.
Re: Tool chain
I don't know which build system you're trying to use there.
I suggest to roll with Linux but apparently Windows works too. In Debian based ones you just do
apt install gcc-arm-none-eabi build-essentials
Thats a useful line I could add to the readme.
dima
Re: Tool chain
Post by dima »
With Windows, you will need to install "Python" to build "libopencm3" + GCC + arm-none-eabi to build actual firmware.
It is not easy in Windows, I use a script to build.
EV_Builder
Re: Tool chain
Eeekss..... i hoped on a arduino style toolchain. Can't imagine that isn't available for a STM32 MCU...
Nobody went the Visual Code and arm-none-eabi way of doing things then....
Think i will crank up a VM then :)
Re: Tool chain
Haha, Arduino didn't really exist when I started this code :) This is much better though, all self-contained bare metal stuff.
You can also try https://gitpod.io/#https://github.com/< ... stm32-sine
Just fork the project to your own git account then you can develop online if you want
EV_Builder
Re: Tool chain
Well it's just that i'm not that fit in toolchain setups and operating systems etc.
Yeah, i already downloaded everything. Now i need a toolchain.
And not only the compiler. Which IDE do you use?
EV_Builder
Re: Tool chain
- First thing i wanted to build is auto-tune :)
- More CANBUS less WiFi
- C# GUI??
If i get the toolchain running i will start converting my inverter :)
Re: Tool chain
Sounds good. I use Code::Blocks as IDE. The cbp file is the project file.
EV_Builder
Re: Tool chain
OK I got code block setup but you have projects inside projects so i miss a bunch of dependencies.
Isn't there a project snapshot incl. all dependencies?
Re: Tool chain
Executed "make get-deps" ?
EV_Builder
Re: Tool chain
That fails saying first no git (ok i know wy you leave that out, but i started vanilla) then it says its not within a GIT directory...
I compiled the "libopencm3" but then i get a big bunch of cpu folders/ wich part needs to be copied to the project?
(i assume this since make errors out with a reference to stm32/usart.h but in the stm32 folder in the library there are sub folders...)
For the rest almost there then :)
Re: Tool chain
No other steps, make get-deps thats it. Yes some tools must be missing, it's so obvious to me that I can't explain it ;)
EV_Builder
Re: Tool chain
ok i figured out i should use GIT... this works way easier. So i was too old school there :).
Now your commands work (obviously).
For Linux:
  • create a VM with Ubuntu (for example)
  • sudo apt-get install (ide of choice, git, gcc-arm-none-eabi)
  • create a directory for GIT clone (mkdir .....)
(omit the version tag if you want master/develop)
  • make get-deps
  • make
Re: Tool chain
Great :) I added the apt line to readme. Just wondering, why did you pick the "-source" package instead of just gcc-arm-none-eabi?
Also cloning the 4.94.R branch won't get the newest sources, I suggest you omit that.
EV_Builder
Re: Tool chain
oww some typo's i corrected the post.
EV_Builder
Re: Tool chain
It would be useful if you check in a new folder the commands. Build the bin and compare it. Tobe sure that references etc. and everything results in the same binary.
At Least its how we at work check the toolchain. Build something (old version/release) and compare the bin file.
We don't accept new binaries if the input was the same.
