Ok I double checked all the parameters and switched my encoder to AB instead of single.
Also the ilgain I think is accurate, if I change it to -1 it reads a positive number when it should read 0 (before the start signal happens). Maybe the multiplier changed with new software/hardware versions?
With the encoder changed, the motor would spin at a snails pace and jog (whatever the word for clunk and not smoothly spin). Adding throttle made it spin very slightly faster. I switched back to single mode and now it runs like that in v4.76 and v4.71 all the time. It still will not close the main contactor in the newest test version or 4.56.
I also tried swapping my encoder wires and it has the same run ability no matter which way they are connected.
I even tried a different battery just in case.
Unless I have a dcnom value it won’t spin at all.
So now it runs even worse than before!
MaxTE7
Hi Guys, I'm a new member here,
I'm slowly gathering parts for an EV conversion I am planning and I've finally received my esp8266 and my rear drive unit inverter control board. I was just wondering what web interface you guys are using for setting these values as I have seen many different ones in Damien's videos and on Github.
Ex:
https://github.com/dimecho/Huebner-Inverter
https://github.com/damienmaguire/ESP8266-WiFi-Interface
https://github.com/jsphuebner/esp8266-web-interface
Which one do you guys use so I can have a similar experience and have an easier time asking questions about values and connectivity and such in the future?
Ex:
Which encoder wires were swapped?wigman wrote: ↑Thu Apr 16, 2020 5:42 pm Ok I double checked all the parameters and switched my encoder to AB instead of single.
Did you try uploading the full json file I linked?
Single encoder is the wrong setting for this motor. Theres no debate on that.
I only use the files from Johannes github.MaxTE7 wrote: ↑Thu Apr 16, 2020 6:20 pm Hi Guys, I'm a new member here,
Ex:
I swapped a and b. In the stock and swapped positions everything acted the same.
I loaded the parameter file and the motor won’t turn at all. (If I change the udcnom it will run very slow and very jerky)
I have the encode mode now in AB in every setting I try.
At 100v or so try setting ampmin to 0 and boost to 1000.
Set udcnom to 0. This is messing with boost and fslip too much at this level. At 100v, a 390 udcnom would result in a 1700 boost value becoming 6700 and fslip 5.6. The boost is well out of the range you want to see.
I set ocurlim to -2500 and il1 and il2 to -1. My contactor will flip without overcurrent but it doesn't change runability.
I changed udcnom to 0 and boost to 1000. The inverter will make a quiet whine when put in drive or reverse but the motor will not spin. This has been the case in all parameter settings where udcnom is 0. That's why the motor only spun when I loaded the E30 parameters.
Attached is the current parameters I have for testing.
Also there are the spot values when the ignition is turned on and the start signal has been sent with the main contactor closed and in neutral.
- wigmanparameters (2).json
- (1.28 KiB) Downloaded 362 times
- Has thanked: 328 times
- Been thanked: 847 times
Your heat sink is reading 100C, please stop overloading the drive unit and smashing changes in it without figuring out what is going on.
The inverter is limiting hard due to the temperature reading.
I would advise for extended testing to get coolant flowing. Your settings do not look miles off from what it takes to spin a motor.
If you follow other posts you will see there was a temp sensor errors with MUX. There was an open task created and Johannes posted revised versions that fix that problem. The actual heatsink temp is 23c. Besides that the other versions fix the issue, you can graph the temp on this version and see it toggle from 23 to 100 over and over again due to the programming error. Unfortunately the newest version won’t even close the main contactor so I’m using the version my board came with for testing.
That being said, the inverter is derated with this version, but it’s not even spinning like it was previously. If you read my previous posts, I actually got the motor to spin the correct way with the newest revised version once. 5 minutes later I turned it on again without changing any settings and the main contactor wouldn’t even close. I really don’t think this is a software or parameter issue.
The main thing I don’t understand is why my board came with a single encoder setting and not AB since it was a built and tested board. Also, the board came with a bad solder joint causing an overcurrent code that would have given the same code had the board been tested before it was sent.
- Been thanked: 1115 times
As I mentioned in a previous posting the solder joint was quite likely my fault as the connectors are hand soldered. I either missed or didn't correctly solder the pin in question. A test of the current sensors does take place and would have had to have passed or I would have found the underlying cause. I can not say why single encoder mode would have been selected. That absolutely should not be the case. So again , most likely my fault in not saving a parameter.wigman wrote: ↑Fri Apr 17, 2020 5:20 pm The main thing I don’t understand is why my board came with a single encoder setting and not AB since it was a built and tested board. Also, the board came with a bad solder joint causing an overcurrent code that would have given the same code had the board been tested before it was sent.
Just to put this in some perspective. I run a Tesla drive unit in one of my cars with the first hand soldered prototype board. I would not sell a design that did not work. When problems arose and oh boy were there problems with getting the bugs out of this and the small drive units, I stepped up. In no small part due to the ongoing problems being experienced by wigman I have handed over sale and support of drive unit boards to Johannes as it is grossly unfair for someone to have to fault find a board bought as tested. I am sure he can and will provide a better service than I could. So there is no mystery here. Damien Maguire messed up wigmans board. Can I be any more explicit? So let's wrap this up. Please contact me offline and I will arrange a refund for your payment. I would then suggest contacting Johannes for a replacement board. I do my absolute to help everyone but yet again it seems find myself lacking. Perhaps time for a rethink...
- Kevin Sharpe
- Been thanked: 10 times
A refund has now been issued to wigman. Here ends my work on LDU / SDU development.
- Kevin Sharpe
Thanks for everything that you have done to make low cost Tesla solutions possibleJack Bauer wrote: ↑Sun Apr 19, 2020 5:30 pm A refund has now been issued to wigman. Here ends my work on LDU / SDU development.
- Been thanked: 1913 times
Alright, time to speak up I guess.
So as mentioned I will be taking over the distribution of the Tesla LDU/SDU logic boards. If I remember correctly about 9 LDU boards are on their way here from Ireland, so these will become available first. A few weaks after I will issue a JLCPCB order to make the others available also.
The boards will be listed on openinverter.org/shop . As for the Leaf boards I will build a test rig and run an automated test procedure. Also the boards will be flashed with software AND parameters in one go, i.e. no manual step here.
As opposed to Damien I will not sell the boards as "fully built" i.e. you will have to solder at least one component. The reason for that is the more relaxed legislation for kits as opposed to ready to use electronics.
One thing I do not have and will never have is a drive unit, let alone a car with it. So when it comes to development work I have to rely on someone who has.
I may put and end to this thread and rather have people create a thread for each specific problem.
- Has thanked: 478 times
- Been thanked: 308 times
Damien - Why do you hate Johannes?
Johannes - Why do you hate yourself?
Just kidding, I'm sure most people buying Tesla drive units are pleasant people. Best of luck with it.
You're right. It's already starting.
Do not send me e-mails asking when the boards will become available. They are available when they show up in the web shop.
Maverick441
- Has thanked: 323 times
- Been thanked: 351 times
I think his answer was pretty clear.
If you dont want to wait, theres always the pcb files on github.
Maverick441
[P.S.Mangelsdorf ][I think his answer was pretty clear.]
Sometime sellers distinguish pre-order and general sale. Pre-order is almost guarantee you can get one, but general sale is subject to first come first serve and may end up waiting for another round. A waiting list could work too, just a suggestion, it could help Johu to gauge how many to order and make.
It will be good to know roughly how many Johu is making for the first round. I can wait a bit, but knowing the rough time frame will help planning. If I need to wait a year, I may go the pcb route... but I couldn't test.
- Kevin Sharpe
Already answered;Maverick441 wrote: ↑Sun Apr 26, 2020 5:20 pm It will be good to know roughly how many Johu is making for the first round. I can wait a bit, but knowing the rough time frame will help planning. If I need to wait a year, I may go the pcb route... but I couldn't test.
Thanks for stepping in. I have received the first 7 boards from Damien and it's SDU not LDU boards. There are quite a few things to cover before sale can start, all of which happen in parallel to my regular job, the BMS, the Toyota board and the forum. That makes it hard to predict when sale starts but it will certainly happen within months. No clearer prediction, I don't want to pressure myself.
So, things to do:
So, things to do:
- order LDU boards from JLC
- order connectors for both boards
- build test rig for both boards using unpopulated boards as base
- test software
- programming process
- set up kit with minimal paper docs
- set up shop
- muehlpower
- Been thanked: 186 times
A general question, can the BMS reduce the performance of the LDU to avoid deep charging or not to exceed the maximum voltage when regenerating. Or is that guaranteed by the limitations in the inverter software?
The software will limit regen if at max voltage. In reality, it’s not a problem unless you can somehow regen brake down a mountain on a full charge. Losses are greater than the motor can put back
Update on LDU situation:
I have ordered 5 LDU boards at JLC and its accompanying connectors. Unfortunately the 24-way connector will only become available in June. So I'm think I can start supplying LDU boards starting 10th of June.
Damien sent me some bare LDU boards that I will use to build the test rig.
I have created a default parameter set based on Jon Volks parameters and I have hidden away everything that only has adverse effects when changed. In addition I could program the openinverter CAN standard by default.
