EVSE controller PCB
Has thanked: 328 times
Been thanked: 847 times
Re: EVSE controller PCB
Have updated the manual, please have a look and let me know if anything is still unclear.
SimpCharge Manual V2.0.pdf
(326.49 KiB) Downloaded 411 times
langoo
Post by langoo »
How would you like to collect orders for this amazing gadget? 👍
Robin Guldmyr
MR Electronics AB
langoo wrote: Wed Aug 12, 2020 8:45 pm How would you like to collect orders for this amazing gadget? 👍
you can email me at: the email address in the manual :)
IanG
Post by IanG »
Hi Tom,
I have, hopefully, a quick question.
Can you please describe the spec of Pin 8 the “Conditioned Pilot Signal”.
I have an old AVC2, and use both an old granny cable at 10A and a standard Type2 at 32A 7kW, but have to manually change the charge rate. I’d like to use Pin 8 on SimpCharge to control the charge rate via my VCU, so it’s all automated.
Cheers,
Ian
IanG wrote: Wed Jan 10, 2024 4:55 pm Can you please describe the spec of Pin 8 the “Conditioned Pilot Signal”.
It literally is a buffering of the CP signal, so you need to have an interrupt capable output to be able to determine the duty cycle.
