EVSE controller PCB
- Has thanked: 264 times
- Been thanked: 717 times
Re: EVSE controller PCB
Have updated the manual, please have a look and let me know if anything is still unclear.
SimpCharge Manual V2.0.pdf- (326.49 KiB) Downloaded 406 times
How would you like to collect orders for this amazing gadget?
Robin Guldmyr
MR Electronics AB
MR Electronics AB
Hi Tom,
I have, hopefully, a quick question.
Can you please describe the spec of Pin 8 the “Conditioned Pilot Signal”.
I have an old AVC2, and use both an old granny cable at 10A and a standard Type2 at 32A 7kW, but have to manually change the charge rate. I’d like to use Pin 8 on SimpCharge to control the charge rate via my VCU, so it’s all automated.
Cheers,
Ian
Cheers,
Ian
It literally is a buffering of the CP signal, so you need to have an interrupt capable output to be able to determine the duty cycle.
