Previous posts were from the now M3 hybrid thread. There's not too much going on there either as I really need to get this done first. I've made good process on the M3 SMG gearbox control recently, but that's about it.
As for the 330, here's the current plan:
Drivetrain:
* Nissan LEAF EM57/EM61 motor. ~$500. [ 2 inputs @ 400A should produce significant amount of torque out of this ]
* UUC Dual-Disc clutch + lightened flywheel (what's on the car currently)
* SMG/SSG 6-speed BMW gearbox
* Stock differential
* Adapter assembly $250 ???
* Leaf spline adapter $300 including shipping
Inverter:
* Chevy Volt Inverter (part # 12643810) - $81!
* Chevy Volt HV Cables (part # 24274910 and 24274911) - $235
* Ampera control board from Damien - 100 Euros (~$112) value.
VCU (Vehicle Control Unit):
MoTeC M130 with custom software. Will control SSG gearbox, and contain torque -> demand calculations to keep everything running happily.
Purchasing from business partner from the first car I did development for MoTeC M1 on.
* M130 ECU
* Logging Upgrade (Up to 2000 items, and up to 1000 Hz rate (not both!))
* Analysis upgrade (Motec has standard and "Pro" edition of their i2 software, I accidentally purchased this upgrade, oops, had to eat the cost..)
* Development package (run your own software on it)
Value: $6487
Cost: $750
Sane configuration: M130, Drobnak Software "DS BMW E46 OpenInverter EV" package, Level 2 logging (200 channels at 200 Hz) - $2295 + 650 + 329 = $3274
Batteries:
* 108 CALB L173F163B from https://www.electriccarpartscompany.com ... -l173f163b - 108*165.50 = $17,874 (Ouch) - 1300A max for 10s!
* Orion BMS 2 for 108 Cells ~$1800
* Battery Box / Assembly - ???
HV Junction box / in battery box:
* 2 GigaVac GV200 Contactors - $140
* 1 GigaVac MiniVac Contactors - $40
* 1 400A 500V A50QS400-4 Fuse - $30
* ISA Shunt - $181 + $15 wire transfer fee = $196
* BUD Clear-top junction box $66
Charging:
* Tesla Model 3 Charge Port ECU $45
* Tesla Model 3 Charge Port + HV cable $210
* Tesla Model 3 Charge Port Door $54
* Tesla Model 3 PCS $265
I will also attempt to break down costs here.
Running value: $81 + 235 + 112 + 3274 + 3110 + 30 + 460 + 140 + 40 + 30 + 196 + 475 + 255 + 45 + 210 + 54 + 265 - 1350 + 300 = $7962
Running cost: $81 + 235 + 0 + 750 + 3110 + 30 + 460 + 140 + 40 + 30 + 196 + 475 + 255 + 45 + 210 + 54 + 265 - 1350 + 300 = $5326
When I have a component in hand, I'll update the cost.
Edit 2022-05-31 - Added value recovered by selling 6 LG batteries. Add new plan for batteries. Moved all outdated info to outdated section below this changelog.
Edit 2020-06-08 - Struck through some text that is no longer applicable.
Edit 2020-06-09 - Removed Leaf motor references, not going with that. I think this is going to be a fun setup when done.
Edit 2020-06-14 - Organized into categories as the list has gotten larger. Added value vs out-of-pocket cost.
Edit 2020-06-19 - Batteries arrived! Updated info on the Remy motor...if someone is interested I'll pass on your info. Costs updated.
Edit 2020-08-18 - Add Tesla Model 3 parts, add temporary Nissan Leaf charging port price into the equation.
Edit 2021-03-23 - Add Tesla Model 3 PCS, Leaf motor, Leaf spline coupler, remove mystery motor reference for now.
Outdated info:
Drivetrain:
* Remy HVH250-115-DOM motor (Motor is repairable, but found a better option...) - was going to be $1800!
* Mystery motor [ ENGIRO GmbH 260W-08011-ABC ] . Gonna be good.
Batteries:
* 6 LG Chem / Chryler Pacifica batteries ($450 * 6) + $100 "crate" fee + $310 Hazmat residential freight delivery = $3110
* Chevy Volt BMS slaves - $30
* Simp BMS - 459.88 (Simp BMS - Volt Gen 1, CANBus Expansion, Connector Set, Shipping - 350 GBP, $5 USD PayPal fee)
Charging:
* Chevy Volt / Lear charger w/ DC-DC - $475 from Jon Volk [ Actually from CODA car ] - Going to use this on the M3 or the bench instead...
* Sell the EVCC charge controller that was included for $???
* J1772 AC charge socket + CHAdeMO socket from LEAF - ~$250 - Round one - $255 inc shipping
-- Need to see how badly the CHAdeMO one is messed up in real life. Bad. Only good for some reverse engineering work.
* CHAdeMO Control board, contactors - $? (Phase 2)
Other specs:
* Torque peak (Is this linear to current?) ends around 4500 RPMs at 85% value (600A?)
* Pack size of ~16 kWh / 50 miles range at 100% usage
Rating is 480Nm at ... 700A. I think the Volt inverter with Arber333's board will do 600A. It's unclear if combined IGBT current was 1000A, or they are 1000A each! If the latter...That's gonna be fun.
