Right back at ya big boy!Gregski wrote: ↑Mon Apr 27, 2026 2:45 pm thank you and yes they do, I even own a couple of them and thought about testing one of them in my kitchen sink with that PWM controller off of AMAZON but you may have just saved me the trouble, I wonder if your code and the Arduino gizmo will work on the GS450h/Camry/Altima ones
also, almost 3 years ago I was running your solution in my truck against the Tesla Model S pump, again thank you very much for sharing your work
Bunky the eBug: A 30 Day EV Conversion
Alibro
- Has thanked: 507 times
- Been thanked: 325 times
Re: Bunky the eBug: A 30 Day EV Conversion
- Gregski
- Has thanked: 635 times
- Been thanked: 1611 times
one of the things I don't like about this Ding Dong charger is that it's cooling ports are closer to 3/4" so slightly larger than all the other components (inverter, radiator, water pump) which have 5/9" ports, so I needed to order some reducers and since space was tight they had to be elbow
Hypro 3/4" Hose Barb x 5/8" Hose Barb Poly Elbow Fitting
https://www.spraysmarter.com/hypro-3-4- ... yGWJsbVxDD
and so the elbows had to be shortened, thank goodness for the extra rows of barbs
- Gregski
and let's see how that fits... good enuff for the girls we date!
- Gregski
what the hell? since when does plastic beat metal?
- Gregski
The Greg did not even skip a beat...
and we have clearance Clearance
- Gregski
I was dreading wiring up this Ding Dong Charger/DC-DC Converter but here it goes
first up was this SINGLE WIRE low voltage regular 12 volt car battery charger cable, ie alternator cable
and folks we just don't have that kinda room
- Gregski
I bet this thing is held on with one bolt
Ah, yup!
Ah, yup!
- Gregski
I will post excruciating detail of me having my way with this Ding Dong charger here I just bought a Dilong aftermarket charger - Now What? so that we can keep this thread focused on the bigger picture and our mission (driving to Costco for a slice of pizza) in case I haven't mentioned it already
- Gregski
so out came the stock thingie
and we set out to make our own
- Gregski
- Gregski
then I made the high voltage battery cable [more detail here: I just bought a Dilong aftermarket charger - Now What? ]
and checked for clerance
- Gregski
when searching for a charging receptacle I was surprised to find one at Walmart, so I had to order it
I don't think this could have come with a shorter tail
Alibro
You do realise that every Nissan Leaf in the scrap yard has that connector. Also if you go for the 2011 model the cable goes all the way to the boot (trunk for those across the pond)Gregski wrote: ↑Tue Apr 28, 2026 3:43 am when searching for a charging receptacle I was surprised to find one at Walmart, so I had to order it
nino500
- Has thanked: 10 times
- Been thanked: 4 times
Lucky we're open source or you might be running into copyright issues with Damien there.
P.S.Mangelsdorf
- Has thanked: 323 times
- Been thanked: 353 times
I know I'm a bit late to the party, but I did want to point out some concern with the coolant pump. It does look a little different from the Prius ones that have been the bane of my existence, but similar enough that I want to flag it - I've had nothing but problems with Toyota pumps, especially but not limited to junkyard ones. They work great at first, and then they die. Best case, they simply die. Worst case, they try to set the car on fire.
I've switched over to some Bosche ones found on the front of the engine of the VW CC (and I assume other VW/Audi products) which, while a bit of a pain to mount, have proven much less likely to combust.
- Gregski
Where?
- Has thanked: 479 times
- Been thanked: 314 times
The Beetle is half way to a bicycle. The flex in the frame is part of the suspension!HlektrikosVasilis wrote: ↑Sun Apr 26, 2026 6:30 pmWatching as you bolt everything directly to the chassis is not good! Especially the VW Bug chassis is not one of the sturdiest and as it goes over bumps and flexes, the inverter, radiator etc are not gonna be very happy.
Alibro
- Gregski
are we talking about the same thing? I was thinking of that dreaded 15 piece low voltage DC single wire chrome connector?
oh and that Leaf charge receptacle has leads even shorter than the Walmart one
Alibro
- Been thanked: 1139 times
Greg, you are the Mr.PoleBarn of the EV community
- Gregski
ha ha, are you saying I need to buy a JAAAAAG ?
At some point yes. Also, have you heard of someone called Bondo Billy?
- Gregski
No, that one is new to me... GOOGLING ?Jack Bauer wrote: ↑Wed Apr 29, 2026 6:10 pm At some point yes. Also, have you heard of someone called Bondo Billy?
Bondo Billy is excessively eccentric, but seems to know his stuff. He's the guy I wish I would have found when I welded my two cars together with an old POS flux-core welder. The secret to using flux-core for autobody work is to have large stick-out, like, 3/4"-1". And then instead of being a manageable consolation, it actually has less deformation than proper gas-on MIG welding.
