I think that the BrakeLight is only triggered via regen braking and that is why I don't get bake lights when the car is sitting not in run mode and not regen braking. I just wanted to check that is the case before I go do some funny wiring. I like the relay as it is a combo fuse-relay setup, and my rewiring to have both regen baking and the old braking would bypass the fuse and use the old cars system which has 3 fuses for the whole cars electrical system.
Is my assumption about BrakeLight correct?
